as I said yesterday ,out of the box it sounds terrific and only gets better with time
I probably have the simplest and most unorthodox network than most everyone here and I can say that I don't feel I am leaving anything on the table as some are suggesting.The only addition I used were LPS for my cable modem as well as my satellite. I stream wireless from my router to the satellite in my sound system and use copper from the satellite to the Extreme. It is so good that it changed the way I listen to music
And one last thought. I don't know anything about waverMay and am sure it must be excellent as well.However what Extreme owners get that no other non Extreme owners get is Emile, who IMO has endless energy, coupled with a brilliant mind and an overwhelming desire that the Extreme be the best server out there. As a result Emile’s handwriting on the wall with respect to the downturn in SQ coming from Roon with each new update.Emile took the bull by the horns and hired a team which in 6-8 weeks completely designed the Taiko Audio Server which IMO is the only path to follow as TAS now at its inception is already somewhat better than Roon
The fact that the Extreme will come loaded with both Roon as well as TAS plus the upcoming Taiko remote that can be had at the App Store when it comes available, will allow the user to pick and choose. I know that Emile's goal is to create his TAS that will always best Roon. Knowing Emile and what he represents, for me TAS is the path that I am gong to follow because Emile to date has delivered on every one of his promises. TAS is the future. Roon is the present
Hi Steve,
A bog standard network would usually comprise the ISP receiving device (modem, cable modem + router) and an ethernet cable or wireless connection to your hi-fi. In your system, you have an upgraded router, on a low noise power supply, you have complete galvanic isolation thanks to the wireless component, you have an LPS on you Orbi satellite and no doubt you use a high quality, well screened cable between your Orbi and your Extreme. In short, a very simple, well optimised, low noise network stream.
When I was installing my system, I was essentially starting from scratch with only a rather crappy ISP modem/router and weakish wi-fi to everything. Because I was starting from scratch and because we have 3 big consumer electronics stores within 10 miles of where I live, I could try out a whole plethora of different network strategies and devices, including a $2000 ethernet cable of known quality between my router and system (I actually ordered this with my system as i was convinced wired ethernet would prove to be superior) But, for me, by far the best solution in terms of SQ was wireless. I was totally biased against wireless, given its use of cheap-as-chips mass consumer grade electronics and the fact its a huge source of RFI, but the evidence of what I heard didn’t lie. By far the most transparent, natural and impactful listening experience was provided by wi-fi. And it wasn’t just good, it was magical.
Adding LPS power supplies uplifted the performance yet further, a high quality router with hi-fi dedicated 5GHz channel the same and the quality of each cable in the system had a positive impact. Placing modems, routers and power supplies of specialist anti-vibration platforms brought additional small but useful improvements to the point my system now satisfies my every audiophile wish and does nothing I don‘t like. For me, the big acid test of a system are the announcers‘ voices on Radio Swiss Classic. With 128kbps, getting them to sound completely natural and neutral requires an extremely well sorted network. If you ever want to hear the effects of break-in or running-in, just try a before and after with the voices on this radio channel and you’ll see exactly what I mean.
What you have in your system is a very simple but well sorted, low-conducted-noise data stream to your system. Can it be improved? Almost certainly yes, but if you’re not feeling the need, why bother? At some point one really should stop and just enjoy what one’s built, otherwise you‘re constantly waiting for something or other to burn-in. I’ve spent almost 2 years of listening time waiting for the magic to return after an upgrade. At some point that interferes with the listening experience rather than improving it, so shouting ’Stick’ at some point is a very valid and important thing to do. Upgrading can become a compulsion
