low end dsd adc
Harlan Brezhler
4
Hello:
I also read the 'which is the best ad converter' thread and have a question about this new Korg ds-dac-10r.
For location recording I am looking into the Korg mr1000,mr2, ds dac 10r, pcm d100, or a portable pcm high quality converter.
Bruce you were recommending the mr2 somewhere and then I had also read that you preferred the Tascam da3000.
(currently I'm only looking at portable machines). Mainly I'm interested in the adc side not the dac or anything else.
Is it still worthwhile to purchase the mr2 vs. the dac 10r?
Is 256mhz much better than 128mhz?
Do you feel that it is only worthwhile getting into dsd at a higher quality point, ie the da3000, or would it better to stay with a high quality pcm vs lower end portable dsd?
(I posted this in the DAC section with no replies, please delete my other posting)
Bruce B
Apr 25, 2010
7,006
512
1,740
Snohomish, WA
www.pugetsoundstudios.com
I would definitely stay away from something that is no longer supported. Also, as far as I know, the Korg DS DAC 10r needs a computer to record to (AudioGate software). For remote recording, it's not very convenient. The reason I like the Korg MR2/MR2000s and the Tascam DA-3000 is that they have either a hard drive or SD cards built in to record to. Everything is all inclusive. I also like the Tascam because it has digital in/out so you can use a higher end A/D converter if you like.
As of this moment, I still don't think Quad DSD will give you any more than Double DSD. The returns are not worth it and on lower end converters, I highly doubt you will hear a difference. I'm still not convinced I hear a difference even on my Horus.
Harlan Brezhler
4
Thanks, that helps narrow the field.
The DA3000 is too big so it's out of the running.
I might be able to figure a way to make the ds dac 10r portable.
The mr2 is not capable of 5.6Mhz, just 2.8Mhz. Right now I'm trying to decide between 2.8Mhz and 5.6Mhz or higher end pcm.
Is there a big difference between 2.8 and 5.6? and would either be preferred to a higher end pcm?
Bruce B
Apr 25, 2010
7,006
512
1,740
Snohomish, WA
Yes, there is a much larger difference between 2.8 and 5.6 than 5.6 and Quad. If I had a choice between higher end pcm and single rate DSD, I'd pick the PCM.
Harlan Brezhler
4
Great that about answers everything for me. So entry point into dsd must be 5.6Mhz which is the mr-1000 or ds-dac-10r. Hopefully someone will come out with a smaller footprint solution soon enough.
awsmone
1,616
514
435
Canberra Australia
I have been pondering the exact same question
Bruces answers concur with my research
The Tascam is great as is standalone and you can add better outboard converters and it supports spdif 3 for DSD
The korg 2000 I have used and has a hard drive and you can input and export files with a computer
My own use of dsd recordings concurs with Bruce in double dad 5.6 is big difference
This is if for no other reason than that the noise is pushed way higher
awsmone
1,616
514
435
Canberra Australia
i just had a though...what about the older Korg mr 1000, this was portable and supports dsd 5.6 and has a hard drive
Bruce B
Apr 25, 2010
7,006
512
1,740
Snohomish, WA
They are fine if you can find one. I just don't like buying things that are not current and without a warranty
