I just arrived tonight back here will be listening for next few days .Any updates?
also cleaned up the bottom end " Bass " not as muddy sounding.
On furniture sliders and cement floor yesHello rau,
Before the installation of the footers you found the bass of the A5 to be "muddy sounding"?
Muddy bass would be the last thing I would describe about the A5’s. I’m only using the provided spikes into carpet. So my experience might be very different.Thank you.
Agree 100%Muddy bass would be the last thing I would describe about the A5’s
I have found it easy to get muddy bass out of an A5. Depending the amp I pair it with or the cabling I use. Still have a slight amount of muddiness left, but I am also not using the spikes yet (on a floating wood floor), and am very curious regarding the isoacoustics - which would be less hassle for me than going apods or included spikes.Muddy bass would be the last thing I would describe about the A5’s. I’m only using the provided spikes into carpet. So my experience might be very different.
Don't forget to include the Townshend Platform as well. Might outperform all the above-mentioned.I have found it easy to get muddy bass out of an A5. Depending the amp I pair it with or the cabling I use. Still have a slight amount of muddiness left, but I am also not using the spikes yet (on a floating wood floor), and am very curious regarding the isoacoustics - which would be less hassle for me than going apods or included spikes.
Same floor structure as in my room; definitely need to try the Gaia with the A5's. Currently using the Apods and all things considered I'm pleased with the bottom octaves but it couldn't hurt to experiment....no muddy bass here. In fact, very tight, articulate bass. IsoAcoustic Gaias on engineered wood over concrete.
Just a head's up...have used GAIA under a pair of Wilsons on hardwood (now have A5's with Magico Pods) and the "rubber cups" at the base have a very strong suction and adheres to the floor like a MF.....I did pull out the lower rubber portion of one GAIA trying to slide the speaker along the floor. Suggest you'd seek out a silicone slider underside the GAIA to move easily...IMO.Are they the Gaia Titan Rhea or Theis? I've been eyeing the same solution, purely because spiked speakers are a pain to move on hardwood floors.
I initially tried the included spikes, adding small dimpled steel discs, which were good. As I had previous experience with Gaias, I decided to try them on the A5s, and have stuck with them.Same floor structure as in my room; definitely need to try the Gaia with the A5's. Currently using the Apods and all things considered I'm pleased with the bottom octaves but it couldn't hurt to experiment.
MarkusB- were you using the Apods before the move to the Isoacoustic Gaia?
Everything sounds excellent now with the Gaias and break inMuddy bass would be the last thing I would describe about the A5’s. I’m only using the provided spikes into carpet. So my experience might be very diff
I'm thinking about upgrading my Magico A1 speakers to A3 or A5 in an open room, but a general listening area of about about 4m x 4m w/ 3m ceilings.
The speakers would sit about 2.5m apart from each other, with the front of the tweeter about 70cm from the wall, and listening spot about 3m away from the front of the speakers, and about 50cm from the rear wall.
Would an A5 be unsuited for a room of this size? (i.e. too big? I am not looking for volume)
I am happy with a Devialet Expert Pro 440 powering the A1. Would it be a suitable amp for the A5?
A data pointFirst post on this site after reading through this thread, and hoping for some advice.
If I've missed any info that would help, feel free to ask.
My room is approximately 8.5m L x 6.2m W with a maximum ceiling height of 3.5m. In this room the Magico A5 has no problem achieving satisfying listening volumes. For reference, from the listening position, my "normal" listening levels measure 78-82 dB. Achieving 88-90+ dB is no problem except for the rest of my family.First post on this site after reading through this thread, and hoping for some advice.
