Magico A5?
Audire
1,479
1,863
330
FL Panhandle
A dealer told me that Magico is introducing the A5 in Dec 2019. No other details were given. Anyone heard anything about any of this?
A picture of it was posted on audioshark the other day
Thanks for the pic Jambo. I'll check out audioshark to ack. I just ordered an A3 a few days back, so I'm wondering what the sound and price difference would be for the A5.
Just wait till Monday to find out the price
She looks like a beauty! Still no pricing or availability ....
That's not the same midrange or tweeter shown in the teaser Magico posted for the A5. My guess is it could be a new large 3-way stand mount in the S series given the diamond deposition tweeter. I doubt Alon would filter down the diamond BE tweeter to the A series just yet. Though we'll have to wait and see..
Hello Bodhi : You are likely right.
Reactions: Bodhi
Well looks like I called that wrong. Here is the latest sneak peak of the A5. The earlier rendering from Magico has been updated to include the new 5" midrange driver & what appears to be the familar A series BE tweeter. What a thing!
Reactions: Audire and CKKeung
Seems that it can ROCK! :oops:
Reactions: Bodhi
I am looking for new speakers for my spare stereo and HT. These might just be it. Assuming they don’t cost more than my S5 MK2. :)
Reactions: Audire
Official Release:
Hayward, CA (USA) – December 6, 2019 – The largest and most advanced of Magico’s A Series, the A5 incorporates the company’s first 5-inch pure midrange driver as well as enhanced midrange and bass driver cone technology. These new cones achieve unprecedented stiffness-to-weight ratio, a key parameter that Magico has pursued over the past 15 years. In addition, the crossover debuts Mundorf’s new M-Resist Ultra foil resistors for unmatched transparency, liquidity and power handling. “The A Series has been a great success in reaching a wider audience,” said Magico’s founder, Alon Wolf. “The A5 builds on that success with a new 5-inch midrange of extraordinary musicality. And the A5 ‘plays larger,’ with powerfully extended dynamic range.” The three-way, five- driver floor standing speaker retains such Magico hallmarks as extensively cross-braced 6061 aircraft grade aluminum and Elliptical Symmetry Crossover. Finished in brushed black anodized aluminum, the loudspeaker will be available in the first quarter of 2020 at a suggested retail price of
$21,800/pair.
New bass drivers with advanced new sandwich cones
The 9” bass drivers of the A5 feature a newly enhanced version of Magico’s Graphene Nano-Tec cones. Graphene, a hexagonal lattice of carbon, achieves 50 times the tensile strength of high-carbon steel. The new cone design combines Graphene layered carbon fiber with advanced new core materials to achieve the highest possible stiffness to weight ratio. Thanks to extensive computer simulation and prototype tests, the driver chassis achieves an ideal combination of stiffness and damping, minimizing acoustical contribution and maximizing airflow. The new bass unit incorporates oversized components including a 5-inch pure Titanium voice coil and huge copper cap with 1?2” of linear excursion. The super-stabilized magnetic field enables the A5 to really thunder, producing 115 dB SPL (@ 50 Hz, 1 meter), while maintaining very low distortion and inductance below 0.18 mH. Finite Element Analysis (FEA) provides Magico engineers a single platform to assess acoustical, mechanical, electromagnetic and thermal properties. This meticulous testing helps minimize distortions in the frequency and time domains. Borrowed from the Magico M3 and M6, the triple bass driver configuration provides easy room integration, maximum distribution of the floor bounce effect and effortless reproduction of extreme musical peaks.
New five-inch pure midrange driver
The new 5-inch full-cone midrange driver enables wider dispersion and greater midrange transparency. Like the bass driver, the midrange also incorporates an advanced Graphene carbon fiber sandwich cone. A new foam surround helps achieve ideal cone/surround integration, faster settling time and impressively low distortion. The all-new motor system uses a pure Titanium voice coil. The super stabilized magnetic field and pure copper pole cap minimize eddy currents and maximize efficiency. This latest midrange driver sets new benchmarks of measured performance.
High frequency driver
Based on the fundamental design platform and geometry of the M-Series tweeters and shared with the other members of the A-Series, the tweeter incorporates a pure beryllium-diaphragm with an optimized 28-mm dome. Magico encases the customized neodymium motor system in an engineered back chamber with the company’s most advanced damping materials. This enables ultra-low distortion, high power handling, massive dynamic capabilities and extended linear voice coil movement.
Crossover debuts the Mundorf M-Resist Ultra foil resistors
Magico acoustically integrates all five drivers with the proprietary Elliptical Symmetry Crossover topology built with state-of-the-art components from Mundorf EB Gmbh of Cologne, Germany. The A5 will be the first product in the world to offer Mundorf’s new M-Resist Ultra foil resistors. Now perfected after years of development, the new resistors deliver greater power handling, transparency and liquidity. The 3-way network features a 24 dB per octave Linkwitz-Riley filter that maximizes frequency bandwidth while preserving phase linearity and minimizing intermodulation distortion.
Aircraft-grade aluminum enclosure
Weighing in at 180 pounds each, the A5 features a massive, sealed enclosure machined entirely of 6061-T6 aircraft grade aluminum, the same material and construction methods as in Magico’s acclaimed Q-Series. Complex internal bracing helps stiffen the entire enclosure and minimize resonance. A dedicated sub-enclosure houses the midrange driver, protecting it from the extensive back wave energy of the bass drivers. The aluminum has an elegant, brushed black anodized finish.
Driver Complement
1” Tweeter (x1)
5” Graphene Nano-Tec Midrange (x1) 9” Graphene Nano-Tec Bass (x3)
Specifications
Sensitivity:
Impedance:
Frequency Response: Recommended Power: Dimensions:
Weight:
Suggested Retail Price (US): Ship date:
88 dB
4 Ohms
22 Hz – 50 kHz
50 – 1000 Watts
10.5” (W) x 14.9” (D) x 44.75” (H) 180 lbs.
$21,800/pair
1st Quarter 2020
2019 Magico LLC
Wow, that looks like a lot of speaker for $22K. I just wish Magico would develop more efficient speakers with >95dB sensitivity. But it may be physics with the sealed cabinet, I don't know. The A series is looking like a very complete speaker line including monitors and subs. Impressive build quality and tech for the price.
Reactions: Bodhi
They have me tempted. I should upgrade my spare stereo and HT system. The only issue is they would be idle 99% of the time.
I hope it sounds good.
I'm guessing it's WAF will be 0.
That certainly has not been the case with the A3. There are a lot of guys and their wives that just want a simple speakers design that sounds great. Plus can be literally put back against a back wall. Wives LOVE that:0)
PLUS there will probably be grill covers ie, the A3, which really makes the speaker blend in to normal environments.
Reactions: KLH007
Magico's propriety MResist in the new A5
I wonder how much of a difference they make? I would have thought the S series' diamond-coated BE tweeter and superior cabinet would make a bigger difference than a x-over part?
I sent an inquiry to Magico asking how they compared to the original S3, this is what Peter Mackay responed with....
Thank you for your message and inquiry regarding the sound performance of the new A5 in comparison to the original S3.
We are pleased to report without hesitation that the performance level of the new A5 will easily surpass the original S3 loudspeakers. The advancements made at Magico over the past 2-3 years with transducer, enclosure and crossover designs are vast and have raised the bar significantly since the release of the S3.
Reactions: KLH007
