Magico S5 2024 in the house
Incredible report, thanks very much for sharing your experience and test tracks! I'm really curious how you are comparing the M6 to the S5. They must be quite spectacular to be mentioned in that way...Although I've not heard the M6 it's always been on my radar but for sure out of my league price-wise. If the new S5's are even close then these are indeed a tremendous value in the Magico lineup.
I’ve had the pleasure of listening to the Magico M6 on several occasions, paired with different amplifications, and I can confidently say it’s in a league of its own.
The M6 is truly a no-compromise speaker. That said, I’m really impressed with the S5 2024. It represents a significant evolution in the S series and is designed to deliver a high-end experience at a more accessible price point compared to the flagship M series.
The S5 2024 excels its previous generations in musicality, tonal density, and scale, with notable improvements in bass quality and spatial reproduction. While it may not quite match the M6 in terms of detail retrieval, pinpoint imaging, or sheer scale, the S5 2024 has its own "wow factor." It impresses with its ability to produce lifelike sound without breaking the bank.
In terms of technology, the M6 features a superior monocoque enclosure that sets it apart. However, the new S series benefits from advanced enclosure measurements taken during development and upgraded driver technology.
So, if you have the budget and space for the M6, there’s really no competition—go for it! But for those of us looking for something more attainable, the S5 2024 is the closest option in the Magico lineup, possibly surpassing the M3 in value and some era performance, like lower octaves.
Congratulations on the new loudspeakers!
How do you get those power cords to behave so neatly?
Thank you Ron.
I think it is the combination of how the Nordost qb8 was built and the exterior of the cardas clear cables that let them sit like Hanukkah menorah :)
Reactions: Ron Resnick
Thank you for sharing your experience—it’s great to hear how the S5 evolved for you over time. What speakers I’d you used prior to the S5?
I’ll keep sharing updates as I explore more music! Glad you’re enjoying yours so much.
Immediate predecessor was the Magico A5 (now moved to the home theater).
A5 is great way to enter Magico sound, keep enjoying both systems.
Merry Christmas to you and your loved ones.
Reactions: mxk116
For me it was the gateway into the next iteration of the Magico “house sound.” Merry Christmas and a happy healthy New Year.
Reactions: exupgh12
Congratulations @exupgh12 ! I think the S5 is a much more balanced speaker than the S3. According to Magico designer it their sweet spot loudspeaker (design wise).
Happy New Year, Iaxel!
Thank you for your congratulations on the new speakers.
From a sound perspective, at least in my setup, the S5 outperforms the S3. It’s less about a completely different sound—since they’re from the same series—and more about how the S5 handles things. The S5 plays effortlessly, with the ability to reach higher volumes when needed. It also delivers all the lower octaves beautifully, even at lower playback levels.
In the end, the choice between the S3 and S5 will largely depend on the size of your space rather than any significant differences in their sound signature.
Reactions: Townes
I bet they are amazing! Beautiful speakers.
I had S3 MK1, very good speakers. The new models look way nicer . I’m tipping the bass is superb.
I had S3MK2, then S2 2023, and now the S5 2024. It's been an amazing journey.
Both the new S5 & S3 can have amazing bass, depending on the room size.
I visited the friend who bought my S3 2023, they sound amazing at his place and the bass is deep as the listening space is smaller than the space my speakers need to pressure.
Reactions: Audio.Knob
Upgraded my power setup by replacing the Nordost QB8 MKII with the Shunyata Everest 8000 power distributor and connecting my outlet with the Sigma XC v2 power cable. Looking forward to seeing how this change impacts the system over time. First impressions are promising, but more listening is needed.
Nice addition, curious what you think once everything settles in.
Do you plug the amps into the Everest? Power is so important... When I had Everest I plugged directly into the wall with the amps and everything else into the Everest.
Hi Owen,
I don’t have enough outlets where my system is set up. If I wanted to connect my amplifiers to separate outlets, I'd probably need to open an OnlyFans account just to afford the cables!
Everything—except for the network appliances, which are on separate circuits—is connected to the Everest. Within the Everest, Zone 1 and Zone 6 aren’t limited in current draw, so the amplifiers can be connected without any issues.
In my next home, I’ll make sure to install enough wall outlets specifically for the audio system.
As for voltage, I’m not sure how much of an impact 230V has on the overall result. However, I do know that a higher voltage requires lower current, and lower current means less energy is lost as heat when transmitted through wires.
Here is my impression from the Everest and the Sigma XC cable:
Reactions: Protegimus
