E32 dac? I am not familiar.
That is an analog waveform approximated from a digotal file
https://www.exasound.com/Products/e32MarkIIDAC.aspx
Happy listening!
Thank you Greggard, you are a truly gentleman too.I will let you have the last word.
Now I feel stupid as I've never read such advice before.......... and also you can not play the LP twice the same day, due to the high temperature, where the groves are melted, a reason why the needle must be made of the most hard material found on Mother Earth, if you use another material, it will be destroyed due to this high temperature...and so on...
......... 75% bi-distillate water, 20% Isopropyl alcohol, 4% soft detergent and 1% Agepon wetting agent. This fluid kept my LPs like new...............
Clean the needle tip with this fluid. Have a camel hair brush, and two drops is enough for the job. Use a magnifying glass to make sure you remove all the needle tip dirt. Sometimes we think it is clean, and that's the reason of miss tracking.
I put only two or three drops of my fluid to the tip of the brush, and I do the cleaning tip process.You use the camel hair brush dry, no fluids, correct?
I use the plastic one gallon container that I bought to Nitty Gritty long time ago. I do not see a special plastic or special container. Use the one that you dispose when it is empty with the cleaning fluid for the kitchen or detergent.So my question is, what kind of container (glass?) should the cleaning fluid be kept in, and how long is it good for?
