Master Built-What are Owners Hearing That They Didn't Hear With Other Cables
Welcome to the Master Built thread. They are remarkable cables. Like you I found I had to turn the volume down as well.
Be careful as they are addicting. It took me a few years but I’m running a full loom in my system now
When you refer " I had to turn the volume down a bit " how many dB's are you addressing? Thanks!
This is a common reaction to inserting MB Ultra cables in the signal path - I’ve experienced this with the Ultra ICs and with their speaker cables.
IME the change is on the order of 1 - 1.5dB depending on the system. As of yet I have no explanation for why this happens - I cannot believe it is due to lower losses as most cables should not introduce significant loss at these frequencies and lengths. The best theory I have is that the MB Ultra cables are so free from distortions of every sort that they effectively sound louder - i.e. dynamics are conveyed so faithfully that the music effectively sounds louder. There is also perhaps a lowering of the noise floor that helps with this perception of loudness.
It is difficult to explain but real I usually found I had to lower the gain on my preamp by about 3-4 clicks. My impression is that it lowers the sound floor so significantly as the possible cause
Reactions: mountainjoe
Tell me about it Stevie. It's not that it feels loud but rather that the enjoyment comes in at a lower volume than before. The crazy thing is when you do crank it, it can be downright dangerous because there's no pain. Damon was shaking his head as Leif and I were getting plenty stupid while the VSA gents were doing their system set up help.
I got the 2 20A Ultras for the M1s so I just have two more 15As for the U11 subs and the U-USB to go and I'll finally be fully loomed. Me must eats more instant ramen but I will get there eventually LOL
They are working on a DIN Phono but I might not need this. I will likely go Jim's route and go for the Da Vinci 12" for my rear arm which has it's own cable captive. The Stone/Diamond Koetsus are just lovely with this arm.
Cats out of the bag. Wish you were here buddy!
Only until Friday. Too short!
