Feedback on mastersound amps for bi amping Coincident PRE
Good day Ellie,
Based on your extensive experience with the mastersound amps, I would appreciate your thoughts regarding what I have experienced to date with my setup. I have a 845 Evo, with a pair of Concident Pure Reference Extreme mkII speakers (94db with impedance between 6 and 10ohm throughout) , which are in effect a bass cabinet that goes from 20 to 110hz and a head that goes from 110hz up, each wired independantly. Toying with my father’s Mastersound 300B SE, To date, I have found the best sound to be when I bi amp the CPRE speakers with the 300B on the heads and the 845 evo on the bass, with my Space Tech Lab preamp feeding them both and using the volume on the 845 to match the bass with the 300B (which is direct).
I am very pleased with the mastersound amps and plan to stick with the brand, my evo 845 has been my favourite amp by far to date. I have shuguang 845Bs on it, and black treasure 300Bs on the 300B. I would appreciate your thought on what could be an ideal/optimized setup based on the mastersound amps available on these speakers. Would for example a pair of pf100 be substantially better than both integrated ? I guess like yourself it would be tricky to make it work in my room, The 300B being lower and generating less heat, can fit in my audio furniture, but who knows...
Thanks in advance for your thoughts...
Cheers
Good day Ellie,
Cheers
