This is the well reviewed Monk-Audio Phono Preamplifier ($3500 Retail) with Red Wine Audio Black Lightning High-Current Battery Power Supply ($1200 Retail). It is in excellent condition and dead quiet. It has great "on the fly" adjustability and most experts call it a giant killer. I am offering it for $2850.
---WEBSITE INFO---
A preamplifier in a class for the friends of the authentic listening pleasure is now finally available. Uncompromising in manufacturing and classic in design, ensure selected components for listening pleasure. Now it is again possible to the original sound of your vinyl baby to listen without equalizer or digital equalizer.
Five fixed set equalization curves make it possible to reproduce the most important record label of the 50s original. Decca and Columbia are included as well as EMI and the early American LPs, such as RCA, which were cut even after NAB or NARTB standard. Of course, the playback after the RIAA standard is possible. The universality and usability was from the beginning in the specifications. The developers of MONK-AUDIO are proud of the high level of flexibility and uncompromising neutral reproduction of their phono preamplifier.
Three inputs, a two-stage adjustable overall gain, comprehensive adjustments for MM systems, built-in, any time switchable MC input transformers, the possibilities stereo and play back monaural and, in special cases, the sole representation of the inner or outer groove flank, make the phono preamp for the ambitious Listeners indispensable.
The preamplifier is built up continuously and consistently in classical discrete circuitry. The MC input transformers are manufactured specifically for MONK-AUDIO. Along with gold-plated RCA jacks and selected components from renowned manufacturers this ensures a long-term stable and reliable operation.
TECHN. DATA
Equalization curves for Columbia, ffrr (Decca), RIAA, NAB / NARTB (RCA) and EMI
Channel select stereo, mono, left, right
MC-adaptation to all systems have particularly high input transformer
two-stage switchable overall gain
three inputs
heavy metal housing
switchable input impedances MM: 15 kOhm, 33 kOhm, 47 kOhm, 56 kOhm, 100 kOhm, 220 kOhm
switchable input capacitances MM: 47 pF, 100 pF, 150 pF, 220 pF, 470 pF, 820 pF
SPECIFICATIONS
Gain MM: 40 dB and 46 dB; MC: 62 dB and 68 dB
Frequency Response: <20 Hz ...> 20 kHz, ± 0.5 dB (relative to the RIAA curve)
Total harmonic distortion: <0.3%
override limit MM:> 70 mV; MC:> 10 mV
Output impedance: <250 Ω
Noise ratio MC (unweighted):> 64 dB
DIMENSIONS
Width 220 mm, height 80 mm, a depth of about 310 mm, weight 3 kg
Red Wine Audio High-Current Battery Power Supply
PLUG-AND-PLAY REPLACEMENT FOR INFERIOR STOCK AC ADAPTORS
AC power adaptors degrade sound quality. Feed your gear pure LFP battery power and hear:
Improved dynamics
Blacker backgrounds
More natural sounding highs
Better defined bass
A larger soundstage
More holographic imaging
PRODUCT FEATURES
Fully automated power management
Factory-configured, supporting the needs of your audio components
Depending on requirements, unit may be able to power more than one component
External battery charger separates AC noise from product
Hand-built in the USA
---END WEBSITE INFO---
Call Jonathan Tinn at (503) 221-0465 with any questions. Paypal accepted add 3% if you live in the US. If you are an international buyer, only wire transfers will be accepted.
