I was looking to make a decision between the Select and the Premier. Either would be used with the Powerbase.
This might be not the normal question when addressing this comparison, but is one more musical to listen to than the other? Obviously the Premier has more detail and other attributes going for it over the Discrete, however for musicality and fullness of sound, are they equal in this category, or one over the other. I listen to mostly rock and jazz, and not classical.
Thanks.
Thanks.
