No I am not talking about the SELECT or the DAC V, neither of which I have yet to hear or upgrade to.
I am talking about their new QUAD USB input upgrade for their SELECT and DAC IV AND V. After many days of struggling I found out that it will not play QUAD DSD on the DAC IV but only on the V and SELECT, no big deal at this point as it plays all other resolutions on the IV. The quality of the appearance of the input is immediately noticeable with a large back shielded plate. I am told their is much more shielding on this port than their prior but exactly from what I am not sure as I was sent a test unit. The other big and HUGE change is FINALLY this input plugs into a PROI2S board (if you are going to upgrade to this, I recommend inserting the module into the PROI2S and then installing the two as a unit as doing it any other way is virtually impossible).
What is already a stunning DAC and sound has been taken to a new level. As many of you know, I have voiced "some" criticisms in the MSB policy of upgrades, timing of new product, server solutions, etc. Well KUDOS to them for getting it right. If there were no other upgrade path available this new QUAD USB port would be by itself a HUGE upgrade, especially given the price. There is more focus, larger soundstage, refined bass and just a HUGE and focused presentation I have never heard before. While I will be upgrading my Diamond Plus to the V (???Select) if there were no other upgrade I would be a very happy camper.
I have no affiliation with MSB other than being and owner and now a VERY happy one.
When I tested the UMT+ which should have had similar results to this QUAD input given the data path, I was less than enthused. I felt my server and old USB input was superior in many ways. This is a whole new ballgame.
From my perch, VERY HIGHLY RECOMMENDED. I haven't pulled myself away from my system since Friday. Finally coming up for air to relay my initial findings.
