Need burmester 082 expert answer..
kaeksen
25
Norway
In it's settings i can set amplifier to PA lo or hi (originally it was on lo)
What is lo setting for and what is hi setting for, and for what scenario i need both for?
Please provide a detailed answer. :cool:
thank you for your inquiry.
HI level at the 082 integrated amplifier means a higher output amplification about +6dB towards LO level. HI is the standard setup. At high sensitivity speakers where overdrive the signal can use the LO setup.
For your Dynaudio speakers we recommend the HI setup.
This is official answer.
Reactions: kaeksen
