Both
Hyperion will not play on current gain phono stages,
Are you saying that one cannot use the Hyperion with a regular phono stage, even one which supports low output moving coil?
Both
No, he's saying it won't work with current sensing phonos, two of which are CH and VdH. Though the CH has standard MC/MM voltage inputs also.Are you saying that one cannot use the Hyperion with a regular phono stage, even one which supports low output moving coil?
Bazelio, it's really perplexed me how invisible Peter Lederman's creations are on this forum. I don't know if it's the competitive pricing, or Peter's profile, or his quite frankly manic website Lol that means Soundsmith is not in the top half dozen of most talked about carts, but whatever the reason, it's a bit of a shame. I've regularly mentioned my Straingauge in my mad ramblings, but only a few have taken the bait on wanting to discuss further.
Shakti as a hardcore experimenter is maybe a better person to generate a discussion. Certainly if his delving into LPSd Straingauge goes as well as I suspect it will, and properly rivals his >3x pricier carts/Boulder phono, that'll be a massive feather in the cap of designer Peter.
Undoubtedly a marketing truth that will always hamper the Straingauge is it's absence of need for phono. For me, that was a big selling point, releasing funds from sale of my Tom Evans Groove Plus SRX phono contributed 1/3 of funds for the SG.
But for those wedded to tubes or wanting to expt w phono stage flavours, the SG is out.
@shakti do you know with what load you're loading the Hyperion? If you have a SUT with medium DCR and the step up ratio is around 1:8 then it should be OK, I think.
Ah your 500 ohm setting is probably at 470ohm... I.e. 1:10 in front of the 47k MM stage. It really should be higher in value if possible, as there will be some HF rolloff with 470 given the inductance. I'd aim for 700 or higher. The low impedance windings could make a difference too. When I had the Red Sparrow loaner with DCR 13 ohms, it sounded fairly dead on a low resistance SUT. Much better with a 15 ohm SUT.My Hyereion is saying load should be : > 470ohm
DCR is 11ohm
inductivity 2,75 mh
I tried on my Lampizator MC1 in internal step with the 500ohm load position.
It is working, but not the level you would expect from a Hyperion.
I fully agree, that a customized Step Up (and a view of the integrated) will work with a Soundsmith fixed coil cartridge, but the majority of integrated step ups are designed for low impedance, low DCR MC cartridges.
Or someone touting Lampi, no shortage here. I tend to be an enthusiastic fellow, and Soundsmith has had nr zero visibility on WBF as long as I can remember. Just trying to counterbalance.
Yep, the voice getting a little *croaky*.Well surely if people like your products as much there will be a whole posse rather than a lone voice
