Thanks Marcin. Does this work with Windows 10 and which firmware version?
Yes, it does. Firmware is independent. You can use it with the firmware that is currently loaded in your DAC.
Regards,
Marcin
Yes that's it I wonder who turned jack woo on to that tubehttps://wooaudio.com/tubes/usaf596-withadapter
Al is this the USAF 596 you are talking about? Is this the best source?
Thanks, Larry
In short the 596 has the lowest noise floor period
And unless you have one you would not understand how much noise is there.
It also allows for a more close up presentation over all. This is great for studio or small live events
Next it has more air then the tube your using as I own one
It does have less depth in stage and a bit less air then the we 274 b or tak these tubes do have a better over all size and depth and air but less intamacy and higher noise floor
There is no perfect tube but the 596 in all LAMPI dacs I own
Pac
Gg2
On loan trp it's as above
As for output tubes of your system can handle the stock non RK 242 get a pair. They have the high est gain of any tube and speed that makes it very visceral yet still musical
After this combo is in and you make some adjustments that maybe needed It's for me the best digital presentation I ever heard at my place
Ask questions and if I can help I will
So now let the minions jump in for the kill.
Yes you must use an adaptor with it fir any LAMPI devicesAl, Thanks. I see that Woo sells it with an adapter. Is that necessary to use with the Pacific?
Larry
Good to know even though I use j river alone I too use kernel streaming ty for postingActually, I've just found out that the latest Amanero firmware doesn't support Kernel Streaming (KS) which is the recommended output for JPLAY.
Regards,
Marcin
Regards,
Marcin
Thanks for confirming Marcin. I’m planning to reinstall an older verson of the Amanero Firmware (2002b) to enable JPlay + KS, unless there are any other workarounds.Actually, I've just found out that the latest Amanero firmware doesn't support Kernel Streaming (KS) which is the recommended output for JPLAY.
Regards,
Marcin
Hi Al. No vol control on my Pacific (Balanced). I have a SGM Extreme and using a Dave Slagle Emia Silver Balanced Passive Autoformer.Does your dac have a vol control ?
Can you try j river ?
Do you use an active preamp ?
Hi Al. No vol control on my Pacific (Balanced). I have a SGM Extreme and using a Dave Slagle Emia Silver Balanced Passive Autoformer.[/QUOTE
Have you tried an active preamp after the slagle ?
Thanks, Al, for this breakdown. I do use the KR 242 with the RK 5U4G, and occasionally switch in the Tak 274B recti for a change of pace. The RK 5U4G is definitely more quiet and resolving - I agree it doesn't do Z-plane layering like the Tak, but over time, I've come to realize you could get those attributes from elsewhere in the chain (new preamp really helps). The Tak is a mid-range monster though. I'm interested in the USAF 596 hoping it bridges the gap somehow between the two, and, from your description, it sounds like it does.
As I laugh at your comment one question comes to mindAgreed the Tak buffs up the midrange and puts it forward and totally bores me
Do you have an active pre after the vol control ?Hi Al. No vol control on my Pacific (Balanced). I have a SGM Extreme and using a Dave Slagle Emia Silver Balanced Passive Autoformer.
autoformer is passive...but SGM should have galvanic isolation. Top quality server.Do you have an active pre after the vol control ?
Also is this device galvonic isolating as well ?
I ordered the USAF 596 and hope to receive it soon to compare against the other two.As I laugh at your comment one question comes to mind
Is your perception to be for all lol. Hope all went well for you and hope to see you soon hahaha.
I mean this buddy
