Thanks to Goran, Christoph, Colin and Rob. I just ordered my Pacific today. Next up LDMS server. I appreciate all of your feedback through this process.
Congrats on your decisionsThanks to Goran, Christoph, Colin and Rob. I just ordered my Pacific today. Next up LDMS server. I appreciate all of your feedback through this process.
I would be sure to ask Fred or Lukasz to use the new JL Sounds XMOS USB board rather than the old Amanero USB BoardThanks to Goran, Christoph, Colin and Rob. I just ordered my Pacific today. Next up LDMS server. I appreciate all of your feedback through this process.
Good to go on that front.I would be sure to ask Fred or Lukasz to use the new JL Sounds XMOS USB board rather than the old Amanero USB Board
Alrainbow is probably the go to guy for Lampizator noise. Other posts have stated that network gear in proximity of the dac can cause noises. I haven’t experienced this personally and have no network gear around the dac. Definitely not normal, but probably easily remedied.All:
Add one more to the Lampi group - I recently became a new owner of a (used) Pacific, balanced with VCThis was spruced up by Lampizator before it was shipped out, so it is in extremely nice condition. It's still breaking in (as it has new caps etc), but it already sounds pretty amazing. Very spacious and lush without being muddy and great dynamics as well. My previous DAC was the Mscaler/DAVE combo, so quite a different beast and I'm really enjoying it.
I do have one minor issue that I'm hoping the Pacific experts here can help with. While the sound is really great, there's a low grade persistent hum in the low treble range. I don't notice it with loud or normal passages, but becomes obvious when playing soft passages. And of course, once I noticed it, I can't unhear it ;-) The really odd thing is that the hum stops a few second after I hit pause or stop (but not if I mute the Pacific). I hear it on both ethernet input (my primary choice currently) as well as on USB (though it was lower in volume with USB).
My configuration is very simple. The end to end chain from the panel is as follows:
Electrical: 40A breaker -> sub panel -> three dedicated 20A circuits
Source: Pacific as Roon End point via ethernet
Preamp: built in preamp in Pacific using balanced out
Amp: Viva Aurora (SET monoblocks)
Speakers: Avantgarde Trio XDs (just the horns, subwoofers are JL Audio Gotham) I hear the hum in the midsize horn
Suspecting a potential ground loop, I also connected the amps and DAC to a cheap Furman power conditioner (so they are on the same circuit), and while the sound is obviously worse, I still heard the hum.
Any ideas are most welcome. The fact that the hum stops a few seconds after pausing the music is really interesting and am hoping is a tell tale sign of something obvious to someone here...
Thanks!
Anil
you're right. Dumb comment on my partI haven't heard of damping rings used to stop hum'
Thanks a lot for these suggestions! I’m going to try them and report back. They all seem easy enough to do. BTW, the DAC is currently on the floor between the two mono blocks.I'm purly guessing here but it sounds like it's noise from the digital board. It ships on pause as it mutes the digital board to stop any popping as music starts. I'm fairly confident it's noise from you room
a few simple things to take note of.
Shut off all lights any kind of lights except for incandescent if on a sw. And use if dimmers
Fan controls and so on must be off for the testing.
Next routers , tablets
Cell phones
All Must be out if the room for testing only
Lastly don't stack any transformers above or below the dac can cause noises but this noise would 60 cycles so not in tweeter or mids but could be low end mids
Take the dac off your rack place on the floor.
Also try to take a copper foil or even alum foil
While on the floor place foil on top left side
And left side aloan.
Try these in order and post back I'm confident I can help if you play nice and honest with me. mostly this is a dimmer , LED bulbs or wireless router
15 feet away I had noise only when I shut down power to my room and only had dac Pre and amp did I realise
