I'm super GREEN that you can go up to such crazy SPLs,
your room is amazing and dedicated and can take that dynamic pressure,
and as much as I love the dynamics of a healthy rock show,
I personally, don't listen at loud volumes, apparently I'm used to it, and my room can't take such extreme pressures,
In my case, of course, it is a completely different system, and moreover, the room,
When and of course it depends on the recording and the genre,
The display in my pre-amp in various recordings shows the ratio in the digits between 9 to 15
When of course it changes depending on what I hear and my mood at the time, so usually when I listen in "Critical Listening" at varying peaks that range from 70db to 85db. At the same given volume, the dynamics fills the entire room and changes in "mobility" depending on the recording.
