Platform for dartzeel
jasbirnandra
272
27
933
Presently I am using a 19 mm ply made rack for my equipment I saw so many posts claiming the sound improvement if equipment's are placed on a proper Rack,I live in India where good Racks are not available and if you import one the customs and freight is so high that you cant think of one.
So I have decided to buy platforms which are cheaper than Racks and can be easily shipped.
My Question is which Platform will give me a good improvement for the Dartzeel Integrated and PB mps3 as I under stand some equipment do not improve if put on any kind of platform has any one tried any platform under the same equipment as mine and what improvement did you get and what make was it.
Thank you
I know the distributor for DartZeel and PB displayed several times at shows where you don't need expensive racks to achieve the isolation needed. They just used Wave Kinetics footers under the equipment sitting on the cheap wire racks. Whether that was a gimmick or not, I don't know, but it is certainly something you can try without having to spend lots of $$ on expensive racks.
You might want to just try Stillpoints or some type of footer first. Just saying....
Got my NHB-108 on two 3" engineered wood slabs sitting on inverted cones isolated by a ball bearing.
Dartzeel doesn't seem to want or need such things, says so in one of the manuals that they are already equipped with isolating feet.
YMMV, of course.
