I am close to acquiring an Air Tight ATM-300R power amp. Hence, I wanted to get input and opinions on suitable pre-amps as that will be my next system upgrade. Obviously, an Air Tight pre-amp would be a logical choice but I wanted to consider other possibilities as well...
Which pre-amps are other here using with Air Tight gear? What do you think of the synergy / resulting system SQ?
What other pre-amps make sense to investigate?
According to Stereophile measurements: "The input impedance was a usefully high 78.5k ohms at low and middle frequencies, dropping to a still-high 54k ohms at 20kHz."
Thank you.
Thank you.
