Preamp Suggestions
Took you a while to realize you turned out right
Nooooo, merely comfortable in that knowledge ;)
In all seriousness your experiences with this piece of equipment does rather reinforce the tenant that a less than stellar demo of a piece of equipment, in a unfamiliar system, may not always form a true and accurate reflection of its capabilities.
With regard to the slight hard edge you mention, that might well be exacerbated by an impedance miss match or hook up wire however what you describe is IMHO a sonic trait of the factory supplied Sovtek 6550.
How do you know it wasn't an accurate representation with the stock valves? Also yes, I would like to demo it with a SET amp as well as with an analog source. So yes, once I find an interesting piece of gear I do follow it around.
Due to Several hours experience with and without the stock Sovtek 6550, I didn't need to be there.
Due to Several hours expearieriance with and without the stock Sovtek 6550, I didn't need to be there.
Sorry I am not understanding. Are you saying this was an accurate representation of Sovtek, but not of the capability of what can be done by changing the Sovtek? So.the Sovtek is hard sounding on vocals? Changing that, would still retain the massive stage, bass, and slam? And details?
Indeed, IMHO utilizing NOS GE 6550A or 70's gray plate TungSol the stage and base impact remain hugely impressive whilst imaging, separation, tone and texture are all markedly enhanced, I find the stock Sovtek 'glassy' and 2.5 D by comparison.
As an aside, since you are well versed in the black art of 'Mooking' you will appreciate just what they bring to the mix of an already impressive piece of equipment.
Ok, another mentioned that GE were soft and to go Sovtek but NOS, not stock. Have you tried the NOS?
Yes, I rolled pretty much every 6550 going in my previous ARC REF5se except the Chinese production STD/TAD, the best IMHO of the later production valves being older production St Petersburg winged =C= very good indeed however they are unfortunately increasingly difficult to source.
70's production Sylvania were good, very early 60's TungSol solid grey plates were excellent whilst I found late 50's TS Black plates fabulously liquid and 3D on vocals however not linear enough on large scale classical.
Overall, for my part, I find the GE's have drawn the best all round performance out of the ARC pre's I have owned.
Preamps! One of my fave topics. How much are you looking to improve the sound vs change the sound? For example, going up the chain in Pass will retain the same 'flavor' of your overall sound while going to the Ref 6 will change it to a different flavor.
x2. Completely depends on your preference. Any other comments are superfluous comparing one to another in random systems and random rooms with random music samples and random ears.
audio consulting
Subscribing! (as I have the same speakers)
What about that Bespoke passive? Is it worth its price, or is it just like the ones from Music First/Townshend?
If passive, then go with Audio Consulting straight away. The venerable silver rock TVA is not only in my opinion the reference against which Active stages have to be heard (Of course if impedance matching solved)
ypisilon its great but do not know which power amp will suit I am using ayre monos MXR and not very happy
Have you considered a top passive? I realise you need a phono but you could keep the ARC for that. If the impedance on your DAC is lowish a passive could outperform an active in my opinion, as long as your interconnects are not too long. I have had a few active pre-amplifiers inc tubed, but the passive beats them all. more transparency and speed, less bloat or overhang. And before anyone asks, my passive has gobs of bass and extension. That would leave 10K? for a holiday or something else in your system....
