While I am one of those who believe that the best bass requires at least 3 sub-woofers regardless of speaker size, I think your post are over-simplifying the issue. Dispersion characteristics are important in what we ultimately hear in our rooms and the design of a speaker whether it is a 3-way or a 2 ways influence greatly its distortion characteristics...
Yes, dispersion characteristics are important, I just don't think they are inherently better in a passive 3-way. Now, they may be better in stereo, directly under the mid and tweeter (I have my doubts but let's assume...). Then what is the difference between...let's make it very easy without over-simplifying...a Wilson Sophia and a WATT over a forward-firing sub with a driver similar to the woofer in the Sophia? Crossover? With the active subs you can set the crossover point to whatever works. Balance? With the sub you have volume control, you can adjust the balance to the room. To bring the conversation back to where it began, and I apologize for the thread drift, let's make the 2-ways active, and get better driver control and separation up top, too. Do they sound small? That's not what I hear. What I hear is a much better separation of upper bass from lower midrange, of upper mids from treble. I hear the results of faster, more precise driver control and steeper crossovers, resulting greater midrange clarity, faster transient response, better instrument separation, better pinpoint imaging, less bloom and blur. I hear precision instead of what I get when tweeters are reaching too low and woofers are reaching too high and amplifiers are trying to deal with huge impedance variations. There is an explanation for what I hear. There is, thus far, no explanation for why a WATT sitting on top of a 10" passive woofer, crossed over at X would sound "bigger" than a WATT, sitting on top of a 10" active woofer, crossed over at the same point. Maybe we hear the same thing and just perceive it very differently.
Regarding electrostatics - not this conversation, but yes those tall broad panels create an impressive sound stage, and an incredible window into detail. Just don't get a few degrees off axis or it all comes tumbling down. In the end, it's all compromises, and I'm not saying that a couple of 2-ways and a sub or two are the only answer, or even the best answer. I'm just saying that if you objectively examine what some of the most respected audiophile floor-standers are, and what they are actually doing, they are doing the same thing or less than 2-ways and subs, and the only good explanation for the conventional wisdom that they are the bomb and 2-ways/subs are entry level high end at best is that the wisdom is more conventional than it is wise. What does all of that have to do with the pro/audiophile discussion? Unless you're planning on building a pair of mains monitors into the walls of your listening room, the pro market is going to be mostly about 2-way monitors and subs. If the conversation is predicated on the notion that floor-standers are inherently better, it really can't go very far. Best to just go ahead and address that logical fallacy up front, I think.
P
PS: You misunderstood or I miscommunicated. I haven't performed any experiments on any B&Ws.
