Calling my speakers shouty was a joke. As I said above, normally I'd use the type of terms P. Ponk did when describing his headphones.
For some reason I don't quite understand, you have to watch these jokes at times ethan.
I knew you were describing them using terms others wanted (the 'is that better' or somesuch was the final giveaway..not that it was needed). Ah, a bit like the joke on GS that backfired??
Maybe make it more clear next time.
There's a popular "audio book" course for budding mix engineers that trains people to recognize frequency ranges. Anyone who's played with an equalizer can do the same thing. You quickly learn what a 1 KHz cut sound like, and the difference between boosting 100 Hz versus 200 Hz. It's not always easy to nail frequencies exactly by ear, but you can get a broad sense of the different ranges. So from my perspective, that makes more sense when describing the sound of loudspeakers or other devices that are typically not flat.
There is a free program on the net called rezone (pretty sure that's it). If people are truly interested in learning maybe give it a go? All it does is, randomly, install boosts or cuts in a pink noise signal, which you can play over any device out of the computer.
Those cuts and boosts vary in magnitude, frequency and Q, and your task is to learn over time where it is all happening. Then you check your answer. Once you have that down pat, you can have it do it to music too.
Anyway, free and fun, and very educational.
One thing I learned was that when most people (well me, but I think most
) blame the tweeter... 'the tweeter was bright' (this of course depends on the crossover points etc etc)...well it is not the treble frequencies...it was always the mid!! (sub 3k, usually quite less than 3k).
JFYI.
I think I said everything probably coukd be measured, it just has not been done yet. I don't see any additional proof of anything above. Could you please take a look at these graphs of the Aerial 20vt If you could point out if there is anything there that would tell me about the speakers imaging characteristics. If so, point it out, and tell us what it means.
http://www.stereophile.com/floorloudspeakers/aerial_acoustics_20t_v2_loudspeaker/index5.html
Of course that's a personal request.
Wishing you well.
gregadd
Maybe read what ethan writes??
I simply glanced at it, so it is possible I missed it if it is there, but ethan (I'm quite sure) does not talk about imaging being a product of a speakers FR per se....but how
accurately the pair
match.
I did not see (it could be there if I sat and read every single word??) any sort of comparison between left and right. I saw a 'generic' FR graph of the speaker.
Ok, so how exactly does the (single) measured speaker vary from any other taken off the production line at any given time? there are tolerances in components. It is a three way (passive I presume, did not look at the slopes used) so now we have all those tolerances in all those components in multiple crossovers, drivers will and do vary. They have to, it's just the nature of the beast.
I've asked this a few times in a few threads, no answer as yet.
So I'll ask you directly, if that's ok??
You are clear that you feel current measurements are inadequate (simplified but hopefully complete enough in essence, sorry if I have misrepresented you).
My question is simple, HOW do you know they are inadequate?? It seems to be simply a mantra unthinkingly chanted.
You mentioned sean earlier, have you gone to his lab and received any sort of introduction into the process, found out how and why perceptions can be misled, have you gone to a lab, watched measurements take place, then listened to see how each MAY correlate to our perception??
I mean I know you probably haven't gone to seans, but I mean how did you
find out that the current measurements are not enough?
To say what we have are inadequate you MUST have found out they are inadequate.
How did you (and all the others that constantly repeat it)
FIND OUT that they are inadequate.
