Pure power : help
alfa100
175
16
223
South Africa
I Spotted a Pure power 2000 ac regenerator for sale. Considering the unit cos I believe my wall power supply is probably unstable ; some evenings my system sounds terrible and sublime on other evenings. My system comprises Pass Labs Xa 100.8 mono blocks , MSB DAC and MSB TRANSPORT , and Aurender X100L. Tried calling Pure power by telephone but nobody answers. Question is can I trust the brand and would the AC 2000 be sufficient for my kit?
Vienna
497
511
190
45
Hi Alfa ,
I used to own XA160.8 in the past; and had addressed this question to Desmond Harrington of Pass Labs. His response Was that is should avoid any in series filters, and Regenerators
tmallin
WBF Technical Expert
May 19, 2010
511
91
440
67
Chicagoland
Years ago I briefly owned a brand-new Pure Power 3000 AC regenerator (88 pounds worth). I was using it with front-end electronics plus two Sanders Magtech Mono amps. I returned it to the manufacturer soon after purchase because it both produced mechanical hum from within the chassis and through my speakers.
Before I returned it, I contacted Pure Power about this issue and was told that, given the hum problems I was having, the unit apparently was not compatible with Sanders amps. Given the manufacturer's lack of any suggested solution to the hum problem, back it went. I had no problem getting a full refund of my purchase price.
alfa100
175
16
223
South Africa
Thank you. What did get after this?
