Ahhh, that is the experience I was after. Thank you very much. Very helpful.
It's always easy to tell a guy what he want's to hear. But when it comes to telling a guy something that will benefit him best, it's much more difficult.
@bonzo75, if you hear of a used B7 coming up with volume control, I should be grateful for the heads up. Lampi are rare here in Australia, the dealer/distributor isn't especially active.
What is the "BE Engine"?
Bughead Emperor playback software. Not user friendly, does NOT upsample but is the emerging SQ champ.
Not user friendly or upsample? Sounds like the bug folks have some work to do.
Mine is 505x415x105 mm DxWxH without feet , front plate 438 x120 mm WxH , it is ca 6 mm thick.Ah yes, good point. Balanced in preference but its not essential.
Preferably in 230v (officially we are 230v in Aus, but in reality 240v).
Thank you.
px if anyone has the dimensions of a B7, I should be grateful for them.
Actually, I said Jadis and shindo added symphonic coloration, but if you listen instead of spam, you might get it
Congratulatiuons, Bob!
Please continue to make your analog recordings available on 1/4" and/or 1/2", 15 and/or 30 in/s, CCIR EQ, with no NR.
Thanks.
With the toggle on the rear plate B7 is ca 530 mm deep.
Together with my recti RCA which is 105 mm high you need at least 25 cm between the shelfs but the top shelf will be the best solution.
The DSD 256 titles on the Turtle site are DSD 64 recordings that are upsampled to DSD 128 and DSD 256.
None of the dsd 256 files and dsd 128 files of Challenge Classics are upsampled from (native) dsd 64 recordings.
From the article it appears that the Challenge Classics recordings done by the Spirit of Turtle engineers (many of the CC titles) are from DXD masters - not Analog masters or DSD 256 masters.
It's another way to create DSD 256 files - Analog, DSD 256 recordings and DXD recordings. More scenarios to compare....![]()
Editing in DXD means lossless transfer to DSD.
Well not completely lossless. But the lowest loss way we have until multibit DSD editing arrives.
