Mike, do you use an external tape pre or the Studer electronics?
mostly I use the external King Cello tape repro output electronics from direct out of heads.
I also use the stock Studer electronics sometimes.
I have Trafoless (Transformerless) cards on my 1/2" A-820 which do sound better than the stock Studer electronics. I could switch them to the 1/4" if I wanted to.
Thanks, Mike. Did you get your second A820 so you could have one machine to play 1/4" and one for 1/2"? I thought changing heads was pretty quick on the Studers. I got my second ATR-102 to be able to do dubs. Only one has an output for my external prepro. So I use it for both 1/2" and 1/4" tapes.
Larry
Larry,
yes, I wanted another top level machine with 1/2", as well as an easy way to dub tapes with 2 top level transports. and both my A820's have switchable direct head outputs for the King Cello. and I can use the King Cello to improve my dubs over the stock electronics, but only on the output. the input is still stock.
I'm told that switching from 1/4" to 1/2" head blocks and guides (which I've done and only takes 5 minutes) is not ideal due to micro adjustments needed for optimal tape tension for ideal performance. but this is not anything I know for myself, only told to me by much more technically expert people (I cannot defend that perspective). not sure whether that is the same for the ATR-102.
I think one needs some pretty good tools and knowledge to adjust tape tension.
Thanks, Mike. The 102 may be easier to change over, since there is no tape tension to adjust - just replacing the two tape guides and the head block. Have you tried the Doshi (I have the 3.0 which Nick is currently upgrading to his latest version)?
Larry
Larry
I am interested in understanding what the zeel interface is. I was always under the impression that for low voltage signals capacitance was critical and the only way to limit it was with a short interconnect. Time to do some research...
Does King / Cello have a web presence to view their products? Google isn't finding anything.
in the September 2001 issue of Stereophile magazine (page 59-69), Herve Delatraz, before there was any darTZeel company or products, wrote an article about Cable Theory. I am not a techie and this article gets pretty deep in math. Herve used the Engineering School of Geneva and their professor of Physics to assist in testing his theories (Swiss engineers.....hummm). and that was that impedance miss matches in audio interconnects cause smearing.
Herve postulated that very inexpensive cables with perfect impedance matching would out-perform much more expensive cables without perfect impedance matching (my exact experience as well as others).
Q: If you were happy with single-ended connections, why invent another type?
A: There are too many differences among audio interconnects. These differences are not marginal. I examined the problem and wondered if it is really the cable itself or only a problem of mismatch. I conducted an experiment at the Geneva Engineering School and it showed that if you are not matched, you will have some signal reflections. Although these 'echoes' occur above the audible threshold, I found that when you are matched, the sound is much cleaner because you do not have these reflections. It is like the integrity of phase or speed. You do not have any timing errors.
(...) btw; Radio Shack off-the-shelf BNC interconnects work but don't sound nearly as good as Herve's cables he makes. precision in the cable construction and geometry is part of the 'zeel' interface. but Herve's cables are more like $100-$150 (8 years ago....could be a little higher now) per meter or so. about as cheap an interconnect as one can find. (...)
I read the article back in 2001 but don't recall details, however a quick search turned up an overview in this interview at 6moons http://www.6moons.com/audioreviews/dartzeel2/preamp_4.html where he says:
Notice the highlighted sentence - reflections in the ultrasonic range. This is quite true in the digital interface domain, hence the need to perfectly match impedances there (the famous 75 ohm specification for S/PDIF or 110 for AES/EBU - for all the details see http://www.positive-feedback.com/Issue14/spdif.htm), and it's also conceivable to want to filter out ultrasonic aliasing and other noise in those interfaces; hence, a good digital cable is critical.
However, he seems to generalize about ultrasonic reflections everywhere, and obviously that includes the analog domain, but I found no details about that. Moreover, what range does he really consider 'ultrasonic' ("above the audible threshold"), and given all instruments' limited ultrasonic spectra of up to 102kHz or so only, plus the fact that most equipment roll off very early anyway (i.e. they are not wide bandwidth), the devil is then in the details. So you may want to ask Herve for all the details of his research in the analog domain, or someone can perhaps find the 2001 article online. Basically, I'd like to see data that there are indeed reflections in analog interconnections where the input and output impedances of interconnecting equipment are already within a compatible range, and with what cable lengths did he see such alleged reflections.
I also think that cable design has advanced so much since 2001 that a generic statement like this - "that very inexpensive cables with perfect impedance matching would out-perform much more expensive cables without perfect impedance matching" - is probably now over-reaching, as it seems to ignore other problems, like noise pickup, phase issues, etc.
Mike,
Unfortunately it is not cheap at all. At the time I discovered that the cable was really expensive - a 10m (33 feet) pair lists for euro 7000.
are you speaking about the cable Herve makes or the Evolution Acoustics version?
OTOH 33 feet of Transparent Opus V5 (or other comparable performance cable) would be more than $40k.
Fred,
I see you use now an integrated circuit in the head preamplifier. Did the Mark Levinson original ML-5's already have this pre-preamplifier close to the head?
