It's been 10 years since I last changed my amplifier and speakers - a long time in audiophile land! Recently, I found myself wanting to see how much better sound I could get out of my audio system. Over the years, I've found myself subconsciously listening to simpler music and I recently came to the realization that it's at least in part because my system doesn't reproduce complex music well.
With that in mind, I'd like to get recommendations for a speaker/amplifier pair for up to $50k (new or used) total. The amplifier/speaker are the two components that need to match well which is why I'm asking for a recommendation for both together.
Particularly for electronics, I prefer products that have local service and support (I'm in Northern California) even if the manufacturer is international.
Room Dimensions:
20'L x 10.5'W x 9'H
The room is also used for home theater so speakers can't be such that they would block the projection screen. However, the audio system's main purpose is for music and producing thundering bass for movies is not important.
Current System
Audio Note AN-E SPe + Audio Note Oto
I've had the above for 10 years and it plays reasonably well within it's limits, those limits being more complex music. It's also nowhere nearly as resolving as the reference systems listed below, even with simpler music. The bass is surprisingly extended because the speakers are designed to be corner loaded which is how I set them up, and I've found many other floor-standers that are physically bigger sound lean in comparison. The corner loading is also convenient given the narrow room doubling as a home theater.
Reference Systems I've Heard and Liked:
I have not been to many shows but there are two systems I've heard in the past 10 years that I recall liking a lot:
Wilson Watt / Puppy 8 + Lamm L2 + Lamm ML2.1
Acoustic Zen Crescendo MK2 + Triode TRX-2 + Triode TRX-M845
Why don't I just get one of the above systems? Well, I just might. But I thought I'd widen my horizons and see what else is out there.
One thing in common between the two systems above is that they both have SET amplifiers. If you're going to recommend a solid state amplifier, it would be helpful if you've heard a SET-based system at some point for comparison, and that you either didn't like it (so I know your preferences), or that you did like it and the solid state recommendation is as good or better.
Amplification Preferences:
I would like to have the low maintenance and ease of use of solid state, but every time I've tried solid state, I ended up going back to tubes. Every solid state amplifier I've tried in my system feels like it's coloring my system in an unpleasant way and makes me stop listening after 15 minutes. That said, I hope it's just the case that I haven't tried a good enough solid state amplifier so I'm open to suggestions for both (or hybrids).
Heat output is a consideration given California's climate.
I'm open to separates or an integrated, with a preference for an integrated simply to have fewer boxes to manage.
Speaker Preferences:
It can't be too wide at the viewing level or it would block the projection screen. That aside, my experience has been that systems with higher sensitivity (or easily drivable) speakers sound better but I'm open to any pairing that works well together.
Music:
I listen to 40% alternative (Radiohead, Travis, Wilco, Sufjan Stevens), 20% indie/folk, 20% jazz, 20% classical.
Listening Level:
I listen to music with 85dB peaks C-weighted, about 78dB peaks A-weighted.
For those that don't have a decibel meter, this isn't that loud. Dynamics are important, but not about the ability to play very loudly.
For those making recommendations, it would be particularly helpful if you've heard some of the components in the reference systems I've liked above as a point of reference. I look forward to your suggestions!
Recommendations from this thread
Raidho D-3.1 + Soulution 530
http://www.whatsbestforum.com/showthread.php?25501-Recommendation-for-Speaker-Amplifier-Up-to-50k-total-for-both&p=511214&viewfull=1#post511214
- $130k new, $50k used
Magico V3 + Zanden 3000 + Zanden Audio 9500 MK III
http://www.whatsbestforum.com/showthread.php?25501-Recommendation-for-Speaker-Amplifier-Up-to-50k-total-for-both&p=511423&viewfull=1#post511423
- $40k used
Von Schweikert Endeavor E-3 MkII + KR Audio P-135 Preamplifier + KR V900 monos
http://www.whatsbestforum.com/showthread.php?25501-Recommendation-for-Speaker-Amplifier-Up-to-50k-total-for-both&p=511236&viewfull=1#post511236
- $35k new
Magico S3 MKII +Luxman M-900u
http://www.whatsbestforum.com/showthread.php?25501-Recommendation-for-Speaker-Amplifier-Up-to-50k-total-for-both&p=511369&viewfull=1#post511369
- $35k used
Wilson Audio Alexia 1 + Air Tight ATM-1S
http://www.whatsbestforum.com/showthread.php?25501-Recommendation-for-Speaker-Amplifier-Up-to-50k-total-for-both&p=511378&viewfull=1#post511378
- $35k used + new
Magico A3 + Soulution 530 integrated
http://www.whatsbestforum.com/showthread.php?25501-Recommendation-for-Speaker-Amplifier-Up-to-50k-total-for-both&p=511230&viewfull=1#post511230
- $30k new + used
YG Carmel + Vitus Audio SIA 025
http://www.whatsbestforum.com/showthread.php?25501-Recommendation-for-Speaker-Amplifier-Up-to-50k-total-for-both&p=511200&viewfull=1#post511200
- $20k used
Von Schweikert Endeavor E3 Mk2 + Aesthetix Calypso Eclipse + Atlas Signature Stereo
- $20k new + used
Magico Anything + VAC 200iQ
http://www.whatsbestforum.com/showthread.php?25501-Recommendation-for-Speaker-Amplifier-Up-to-50k-total-for-both&p=511457&viewfull=1#post511457
- $20k used
Rosso Fiorentino Siena + MastersounD Evolution 845
http://www.whatsbestforum.com/showthread.php?25501-Recommendation-for-Speaker-Amplifier-Up-to-50k-total-for-both&p=511323&viewfull=1#post511323
- $20k used
Von Schweikert Endeavor E3 Mk2 + Hegel H360
http://www.whatsbestforum.com/showthread.php?25501-Recommendation-for-Speaker-Amplifier-Up-to-50k-total-for-both&p=511251&viewfull=1#post511251
- $10k used
Unsorted
JBL M2 + ?
AudioKinesis Prisma + Lamm M1.2, Thrax Hero's, Pass Laboratories XA25, Thrax Ares
Thrax Lyra + Thrax Heros, Lamm M1.2, Thrax Ares
Ubiq Model One + Lamm M1.2
Volti Rival + Pass Laboratories XA25, Lamm ML2.2, First Watt J2
http://www.whatsbestforum.com/showthread.php?25501-Recommendation-for-Speaker-Amplifier-Up-to-50k-total-for-both&p=511237&viewfull=1#post511237
Room Dimensions:
20'L x 10.5'W x 9'H
Current System
Music:
Listening Level:
- $40k used
- $35k new
- $35k used
- $35k used + new
- $30k new + used
- $20k used
- $20k new + used
- $20k used
- $20k used
- $10k used
Unsorted
JBL M2 + ?
