That is how it sounds. You don't hear it wrong. This recording is not good on vinyl. I found it best sound on Howie's system that you posted video. (Howie I give you a duPre champion medal) He was streaming I think. I listen her on youtube live tv recording better than hearing from my system playing vinyl.I bought the Elgar* - Jacqueline Du Pré, Sir John Barbirolli, London Symphony Orchestra* / Janet Baker – Cello Concerto / Sea Pictures, Warner Classics – 0190295871888, Europe, 2017.
I am really disapointed by the sound quality: du Pré Cello is not detached from the ochestra. I have to crank up the volume at some level that I never go and then got a lot of background noise. Nothing compare what I have heard with my head phone here:
I wonder if other version have the same problem.
Thanks for the answer. My warner version does not sound like CD transfer to vinyl as some european labels do. I believe (but not sure) that the duration of the concerto (almost 30') is too long for one LP's face. They have to reduce the groove amplitudes to fit in and then something on the sound.That is how it sounds. You don't hear it wrong. This recording is not good on vinyl. I found it best sound on Howie's system that you posted video. (Howie I give you a duPre champion medal) He was streaming I think. I listen her on youtube live tv recording better than hearing from my system playing vinyl.
@bonzo75:
I am listening mainly Jazz, Pop and Rock, but I am open to Classical. My whole system cost me only 4/6 of the price of howiebrou pre-amp. Think how I was happy the get my Allnic phono (which corresponds at 80 % of H3000, if you do not believe me, read carefully the reviews) at 40% of its full price ( a demo unit).
I've owned the Warner Du Pre vinyl box-set and I have the speakers corner version of this concerto as well.Someone else has compared the warner to the EMI versions ?
I did not know that Speakers Corner has published it, not referenced on Disogs. I did not find it on Speaker Corner website.I've owned the Warner Du Pre vinyl box-set and I have the speakers corner version of this concerto as well.
The Warner box-set was awful sounding, I literally gave it away.
The speakers corner version is much better.
I don't have the ED1/2 pressing, but it would be interesting to compare, although I'm not quite sure I'd be willing to spend >$200 for a mint and nm copy.
Which ED1/2 pressing version are you speaking ? this erc one ?![]()
I have purchased it many years ago and I cannot recall, I may be mistaken and it could be a Testament reissue.I did not know that Speakers Corner has published it, not referenced on Disogs. I did not find it on Speaker Corner website.
I have read in another forum that the EMI testament issue is the better of the previous EMI versions.I have purchased it many years ago and I cannot recall, I may be mistaken and it could be a Testament reissue.
Anyway, it sounds way better than the recent Warner reissues.
If you do not insist only on du Pre, I will recommend Elgar played by Paul Tortelier with Sir. Adrian Boult conducting London Philharmonic Orchestra. EMI ASD 2906. Tortelier and Boult convey the emotional message through the piece almost good as du Pre/Barenbolm Live tv recording. if you watch from youtube you would even see the hearty connection reflected from du Pre made a small glance at Barenbolm when she was playing. Imo that particular recording tops the rest with their chemistry. Anyway, ASD 2906 that I suggested is a much better recording sonically than du Pre/Barbirolli and du Pre Barenbolm. As a reference, I have all the records mentioned in original. Du Pre/Barbirolli I even got to choose from a few originals that Zerostargeneral sent me. I still think Howie's steaming digital is the best I have heard on this piece. I will ridicule myself if I video this piece and compare to his.I did not know that Speakers Corner has published it, not referenced on Disogs. I did not find it on Speaker Corner website.
I have at least four versions of this , a first pressing, the Testament reissue , the ERC and the 4th slips my mind at the moment. The Testament is indeed very very good, and pushes the original close. I do find the entire recording a bit disconnected for want of a better word and no version I have manages to dissuade me from that view. The ERC is good, not as good as the others .I have read in another forum that the EMI testament issue is the better of the previous EMI versions.
I have ordered the Testament reissue. Just have to wait to received it.I have at least four versions of this , a first pressing, the Testament reissue , the ERC and the 4th slips my mind at the moment. The Testament is indeed very very good, and pushes the original close. I do find the entire recording a bit disconnected for want of a better word and no version I have manages to dissuade me from that view. The ERC is good, not as good as the others .
Received. This reissue is quite well balanced between du Pré cello and the ochestra. Worth the money spent.I have ordered the Testament reissue. Just have to wait to received it.
