The Telos Sapphire must be incredible. Does anyone know the retail price? Does it come standard with the sapphire cartridge mounting plate?
I do think it is incredible......and every day of listening to it brings new musical insights. it simply digs deeper for musical truth, and does it with such ease and effortlessness. sure; you can check off all the boxes as it goes about it's business; but the musical whole is much more than the sum of it's parts. the subtlety and nuance of this tonearm are beyond my ability to describe.
my Telos Sapphire is a pre-production model. and as it is not in final form Joel has not yet set the price. he does expect the final form of the Telos Sapphire to come out later this year.
mine does have the Sapphire cartridge plate; however......as the final form of the Telos Sapphire is not yet firm I cannot say whether that final form will include the Sapphire cartridge plate.
my Telos Sapphire has a few other unique pieces that individually raise the performance bar. (1) the counter weights are made of the same un-obtainium metal as the Telos base instead of stainless like the stock Telos. for the NVS installation the Telos needs a spacer for the base for height; (2) my Telos Sapphire spacer is also made of the un-obtainium metal. other Telos tonearms have the bearing tower made of stainless with a Sapphire insert, and the bearing sets on top of the tip. (3) my bearing is underslung which allows for the use of a special bearing lubricant, and (4) my whole bearing tower is solid Sapphire. on the stock Telos the anti-skate bridge on the azimuth platform is made of stainless; both the posts and crossbar. (5) on mine it is all Sapphire. and (6) the azimuth post on the armwand is all Sapphire instead of stainless.
if I overlooked something I apologize.
my Telos also has an upgraded cable from Found Music, but it's not directly part of the Telos Sapphire 'pre-production' package.
I do have a completely stock Telos sitting next to the Sapphire version that I use for my Miyajima mono cartridge, and it is a wonderful tone arm.
solid sapphire bearing tower, lighted from below with an LED. originally mine was red, but I preferred the white LED.
solid sapphire azimuth bridge and bar, and you can see the spacer below the tone arm base.
un-obtainium counter weights
