I have a scale and I don't use it. That is because I have a mirror over my sink. I can't pretend I have a 200 lb leg in the mirror.I don't have a scale.
I saw your statement after I posted mine Greg. Mirror is not always your friend.
We’ve been around this loop already…reread earlier posts.Thank you, but "upper mid" and "lower treble" mean different different frequencies to different people.
Which frequency or narrow frequency range is the "zing" you are talking about?
I suppose Ron could just ask Gryphon if there is a notch filter in his passive crossover or not.No, ribbons and planars tend to be smooth through the midband. Upper mid, lower treble zing was above that. As I posted, BG tells you that there is a resonance that must be tamed with a notch filter…it’s not speculation and it doesn’t go away with break in. What could happen with break in is that the frequency shifts a bit due to loosening up and matches better with the notch filter.
Ok. My understanding was that the resonance was a function of the cavity in the steel frame not the foil itself. This means that it is inherent in how they build up the driver to deal with the strong magnets and keeping the spacing even fit uniform fields.I suppose Ron could just ask Gryphon if there is a notch filter in his passive crossover or not.
That, and these are unlikely to be the same as the traditional BG ribbons. As I said, BG were working on upgraded ribbons that wouldn't have the beaming issue. Pendragon look like the latest and greatest in a new fascia before BG closed down due to death of one of the principles.
The pair I have don't seem to beam in any obnoxious way that I can tell, and are very efficient when driven directly with no passive crossover.
A mirror is rarely an audiophile’s friendI have a scale and I don't use it. That is because I have a mirror over my sink. I can't pretend I have a 200 lb leg in the mirror.
Sure diffusers are good… but where is the stent and the collagen when you really need itSelf-reflection never good in this hobby
TMIA mirror is also useful for expecting your stylus.
I thought it was on the dark side.I have no Reflection …
Ron, keep the updates coming. I'm excited for you and your system!At the risk of causing the pot to be stirred again.
How is the system coming Ron? Is more time allowing things to settle in and improve?
Have you moved the speakers or seat around any more?
I know there are a number of members here that have followed your progress with the anticipation of a wonderful room and system.
Sorry, a thread once again turned into, casting aspersions of who did what wrong.
Anyway many of us would like to hear how your progress is coming.
