Roon alternatives?
Kippyy
65
22
1,563
San Ramon, CA
I've been using Roon for many years with a mac mini as my server, but lately am seeing more posts that there are far better music players available.
I'm not a do-it-yourselfer and am not very tech savvy. As a result I'm quite intimidated by the Taiko threads, where it seems something is changing all the time.
Options I'm aware of are:
-Pay to apply room correction to Roon after using Accurate Sound
-Lumin U2 transport
-Taiko
Any suggestions appreciated.
Aurender is very simple and works great with their software. I really liked my N20. I think the Aurender products are great but the app for Roon I like better for finding music. For Roon I’m using the Sonore optical streamer.
-Lumin U2 transport
-Taiko
I think you would find the Grimm Audio MU1 a large improvement from the mac mini. It is pretty much plug and play. The only thing to try would be the three oversampling options with your MSB to determine the best sound. This is done via a web interface that is very user friendly.
An in-home demo would tell you if it will work for you. A knowledgable dealer could walk you through the initial settings if it looks confusing to you and then it is set it and forget it. The online manual is very clear about the settings, so you may not need help: https://www.grimmaudio.com/wordpress/wp-content/uploads/Manual-MU1-Software-V1.5.7.pdf
Try Jplay. I gave up using Roon even though I m a lifetime member . Check out Jplay free trial
Reactions: Thundersnow
I've tried several including Audirvana and Aurender. I always come back to Roon. The haters say that the sound quality out of Roon is inferior to other apps but I have never found that to be the case. Not in any way my aging ears can identify.
Cincy
