I presume it is a UK plug, which have fuses.The Prince has a fuse inside?
Can someone explain the Palladium over silver? Is that an extra layer of plating?
i'll likely try the Prince and King together on the Wadax Reference Dac twin power supplies to see the delta there on the Sablon relative to the Absolute Fidelity.Congrats, Mike. A big fan and owner of multiple Sablon Princes (we cannot use King owning to the plug inlet part not being designed/made by Bocchino). Have not tried Palladium though have spoken with Mark Coles about them.
Enjoy! Will be interesting to see if this decision leads to more Sablon Kings. For us, after owning PAD 25th for many many years...we did the wholesale change after years of trying various cables including interim Sablons. The Prince (SR Orange fuse inside) was the one that made the definitive move for us.
Prince UK has a fuse because UK plugs have a fuse directly in the plug itself that goes into the wall.The Prince has a fuse inside?
want to choose words carefully as we have warped minds here........you know it's big, but nothing prepares you for the physicality of actually plugging that thing in when you get it.
hi Mark, figured as much but did not know the details. thanks for the perspective on how it should go. so far it's just a bit 'more'....if a little uneven maybe this morning briefly.Hi Mike, this King cord was barely a twinkle in my somewhat bleary eye when I returned home from Lisbon at midnight on Saturday.
The Sablon elves made it on Sunday, ready for Fedex to magic it to you 5000 miles away within two days. They used to manage next day into west coast but, like many things in life, things aren’t what they used to be.
Burn in is pretty benign - it will start waking up after a day or so and then progressively intensify over the following week. I look forward to your thoughts on its evolution.
My personal feeling is that it is more similar than different to the Prince model in voicing but brings greater liquidity / natural tonal ease / transparency, in a similar fashion to an organic sun ripened fruit compared to a regular one.
Those quotes are now rather old and I have only sold the Bocchino terminated Prince and King for quite some time. Furthermore Bocchino have standardised palladium (over silver) plating a year ago. Little point in looking at the past, so I’ll restrict my comments to the present
The silver plated Bocchino iec gave a dense midrange oriented presentation whereas the (now no longer offered) platinum was comparatively even across the frequency range, with better detail and clearer transients. The current palladium coating falls between the two stylistically and has a wider range of compatibility. I still however offer the silver plated iec to order, predominantly for Taiko Extreme owners.
Mark, assuming that you've heard what the QSA treatment does to the Prince, how would compare its tonality to your version? While I use and very much appreciate the effects of the QSA fuses (red, red/black), I've found the Beldin/Iconoclast based version (Gamma) to be on the dry side.
