Ooh! I didn't know you were there in the shadows sir!That's actually my advert, so anyone interested can message me on this forum too.
What and how many do you have to give the Glanz to drink before he urinates on a Groovemaster? Does he still shine like stainless steel afterwards?Hmm, I have to say, imho, the Glanz MH-104S
urinates all over the Groovemaster with an SPU.
Very true, but the Law of Diminishing Returns applies here, and the Glanz is not four times as good as a GrooveMaster with SPUs! For someone whose pockets are not deep enough to afford a Glanz, a GrooveMaster is a wonderful alternative.Hmm, I have to say, imho, the Glanz MH-104S
urinates all over the Groovemaster with an SPU. It's a terrific combination!
If one purchases wisely and purchases minty used, the Glanz is ($4565) which is not as you say, 4 times the Groovemaster ($2,915.00 - $3,205.00) is it worth the extra $1360? ....I think so.Very true, but the Law of Diminishing Returns applies here, and the Glanz is not four times as good as a GrooveMaster with SPUs! For someone whose pockets are not deep enough to afford a Glanz, a GrooveMaster is a wonderful alternative
Here in the UK, a new GrooveMaster III is up to £2k depending on length, and a new Glanz MH-900/1000/1200S is £7k. Both are freshly revised tonearms, but of course older versions are available on the used market for less, and still worth seeking out.If one purchases wisely and purchases minty used, the Glanz is ($4565) which is not as you say, 4 times the Groovemaster ($2,915.00 - $3,205.00) is it worth the extra $1360? ....I think so.
But if you use the short SPU A types, there is no much modern alternatives to Groovemaster and Schick. If there would be a Glanz 1200 for SPU A, I would immediately buy one.
Point taken about the SPU A , but i think the original post wasn't really referring to the A type?In general, I kow, the Glanz tonearms match well with most of the Ortofon SPU. But only with most of them, not all!
My Ortofon SPU A cartridges ask for a tonearm of a specific lenght.
Do Masataka Hamada and his company produce tonearms to match a SPU A?
@westlower , I think you missed this point. But OK, at the time reading #17, maybe you was to much disturbed by catching some liquids leaking from your Glanz.Understandable
Excuse my ignorance regarding the A type SPU, but does the available adapter for the A type not bring it in line with the regular alignment of the classic SPUs? or do they simply not line upDo Masataka Hamada and his company produce tonearms to match a SPU A?
Care to share your experience with 'the right cable'? Since you mention Mik are we in LFD territory...With the right cable this SME M2-9R is just Incredible, at this or any price point. Mik will vouch for that and that's a BIG recommendation!
As you say, there is the APJ-1 adapter from Ortofon available to bring a normal arm to the, for the A, required lenght.Excuse my ignorance regarding the A type SPU, but does the available adapter for the A type not bring it in line with the regular alignment of the classic SPUs? or do they simply not line up
Indeed the LFD cable family in my system have made an astonishing difference to the presentation, actually a greater leap to what I wanted to hear from my equipment than any Tonearm or component change, it was that big. It did make me rethink the whole merry go round of Tonearm and box 'upgrade'. The realisation that my attention was on the wrong things was a bit sobering. I use an LFD Silver Scorpion on my SME Tonearm and the justifiably much talked about LFD Diamond Viper between Power and Pre. But this is now way off topic, apologies to the OPCare to share your experience with 'the right cable'? Since you mention Mik are we in LFD territory?
Hmm besides optics the real difference is with the materials used. The Glanz uses stainless steel what makes a very special sound. Nevertheless it´s an antique design lacking the more modern and technical beeing worth elements that a FR-64s or FR-66s will provide - applying the tracking force dynamically.I don't have a Glanz, but I have heard one on numerous lengthy sessions with and without SPUs (not an A!)....
the original comment about the Glanz pissing on the Groovemaster was made light heartily but as said, i'd rather spend the extra on a used Glanz example than a new Groovemaster. I have had a Groovemaster and it's ok and does a fine job, but SQ, fit and finish on the Glanz is in a totally different league and the new rrp tells us that. But I was suggesting second hand
There is a quite widespread school of thought that says the FR-64S (and its related brethren) sound better if the dynamic downforce is dialled out, and instead static downforce applied by the counterweight alone.Hmm besides optics the real difference is with the materials used. The Glanz uses stainless steel what makes a very special sound. Nevertheless it´s an antique design lacking the more modern and technical beeing worth elements that a FR-64s or FR-66s will provide - applying the tracking force dynamically.
Thus I´d rather go for a FR-64s and save over 2 grands for some record shopping![]()
I know about those fairy tales. But did you try it out yourself? I did and this saying isn´t trueThere is a quite widespread school of thought that says the FR-64S (and its related brethren) sound better if the dynamic downforce is dialled out, and instead static downforce applied by the counterweight alone.
