Sensitive speakers that slam
Rawlit
34
20
13
45
Hello,
I'm struggling to find the right speakers for my use case
I'm currently using Wilson Sabrina speakers, sound is great, but my room is 25x25 in size and the Sabrinas struggle to pressurize it
Instead of upgrading to Sasha or similar I'm considering transitioning to more sensitive speakers, this will also allow me to use less powerful amps and save some space
What high sensitivity (>92db) speakers would you recommend with similar sound signature to Wilson's ?
I'm looking for an holographic soundstage, pin point imaging, great dynamics and slam with a base that pressurizes my room + WAF )
Budget in the range of my Sabrinas used + 30%
Thank you all!
Hello,
Thank you all!
Hello,
Any inputs? While researching I came across this speakers: NSMT model 100
Would these be comparable to my Sabrinas in slam and dynamics?
Why not simply add some subwoofers? I'm curious which amplifiers are you currently running the Sabrina's with? Is your room heavily damped, e.g. drapes carpet, furniture etc.? If you have a photo of your room please post it and that will help the WBF readership to better understand your current challenges and make recommendations to meet your goals and objectives.
Sabrina speakers are excellent and will not be bested easily at your suggested price point. My own commercial interest aside (we are the US importer), the best solution I can suggest given currently available information is the AEquo Audio Stilla. The Stilla has truly extended bass to 20hz, excellent dynamics, pinpoint imaging and a holographic soundstage. Stilla' uses active bass amplification with a unique and easy to use analog room control system named "ARPEC" that allows easy placement and bass optimization which will surely help and can be powered to high levels by any well designed 75-100 watt tube or 100 watt transistor amplifier. Most of all they are among the most WAF friendly speakers offered at any price (just ask my interior designer wife)!
AEquo also offers a fully active version of the Stilla eliminating the need for a separate amplifier. Pricing in the US is in the $22-25k range depending on features etc.
Listed below is a link to their white papers describing AEquo's technology. Reviews can be found on Mono and Stereo, HFA, Six Moons and others.
Reactions: XV-1
im planning on pairing subs with some efficient speakers - will report back. everything getting ordered :)
Reactions: gleeds and bonzo75
Why not integrate them in the same speaker? Active bass on a very sensitive mid/high section (see above as example) does the trick without integration issues (filter slopes, time alignment etc) if the active section is fully analog.
