As Christoph pointed out I have had 3 iterations of Crossfire.
With Avantgarde Duo Omega the first version, replaced 2 years later with the second one and in 2014 by Crossfire III in setup with Duo Omega G2 and then with Mezzo XD.
I auditioned also Crossfire Evo with Duo Mezzo XD, it is a good amp but the gain is too high for Avantgardes.
My Crossfire III was recently upgraded with Mundorf Silver Gold Evo capacitors and Nichicon regulators, it is under breaking-in period with my Trio LE/ REL setup , very promissing.
I did not try KR 350 in my setup though. Among over 10 other integrated and power amps I tried during last 10 years Crossfire III showed the best synergy with Avantgardes and remains my main amplification. The second one is a Polish hybrid desing A 100 by Circle Labs.
If
@remdeck prefers, Crossfire III exists also as a power amp without the pre section.
But integrated version can be used as a power amp as well with external pre using Direct In connection. Imho Crossfire III is significantly better than two former iterations mainly due to improved pre and power supply sections and tube rectifier .
I also had the Vulcan Evos in house when I had my Crossfire and while they did some things better than the Crossfire, I felt that the Crossfire was actually more transparent on my Odeons. BTW, have you ever tried replacing the 6H30s with 6H6s? I found that I really preferred the sound with that tube in the driver section. Also, replacing the stock Russian input tubes with good NOS (GE or RCA...can't remember anymore) did a lot. What are you using for the rectifier? I had an Ayon Branded EML 5U4G. That being said with the Aries Cerat Genus I don't think about these other amps so much anymore...same power rating...another league (and I owned and loved the KR VA350i for about 5 years).
The best SETs I have owned in order from the best to the worst:
Aries Cerat Diana Integrated (on everything except my Odeons...it was strangely overdamped in the bass)
Aries Cerat Diana Forte (for all non-horn speakers)
Aries Cerat Genus (just below the other two on everything else but the best I have had on my Odeons)
KR Audio DM monos (had for review and drove electrostats wonderfully, full emobodiment of the KR sound)
Ayon Crossfire III (on my Odeons...didn't try on too many other speakers)
KR Audio VA 350i (great all around amps...probably a bit better than the Ayon on "normal" speakers)
Ayon Vulcan Evo monos (great but not as good as the above and a lot more expensive...had for review)
Wall Audio M50 monos (Powerful PSET with great punchy sound and engaging but not as transparent and a bit golden colored)
Ayon Spark MKI (new acquisition but sounds promising...might move up a spot or two eventually)
Lady Day LD+ 300B monos (when playing horn only moves up a few spots with that 300B stuff going on)
JJ-322 (great bass and mids but the highs were curiously reticent...good inner resolution as you expect from a 300B PSET)
NAT Symbiosis SE (Not true SET but is single ended hybrid...unique...moves up 2-3 spots after playing for 2+ hours)
Cary CAD-572se (had a long time ago and might be better than this...speakers were very different then)
Mastersound Dueundici (a SEP and good clean sound but not at the level of those above...inexpensive relatively though)
In the under 20K category, it is Genus, KR Audio VA350i and Ayon Crossfire III that I think are top integrated contenders.
