Zu Omen Dirty Weekend loudspeaker is our hook, the best that can be done without making regrettable compromises in performance, materials or life-long quality.
www.zuaudio.com
Just one example but there are many more. ZU uses the 1 watt/1 meter efficiency spec since a lot of their market uses tubes.
The last statement of your post (although with good intent) is false. The consumer will only get an approximation of sound pressure if the impedance of the speaker is 8 ohms; but if the speaker is 4 or 2 ohms the power they may need might have to be double or 4x more. You can't correct the statement using the word 'voltage' to replace 'watts' as amps are typically rated in watts rather than voltage.
With SET amplifiers this is particularly true since they do not behave as voltage sources!
The second paragraph in your post touches on an interesting topic that I've talked about for many years- the tendency for audio to dive to the bottom in the chase of the almighty dollar. I think the first example of this (anywhere near the hifi era) was when the industry went from field coils to permanent magnet loudspeakers, which are cheaper to produce. The next time was when it moved from tubes to solid state. At that time, amp manufacturers saw that they didn't need to make an output transformer and didn't need a filament circuit, allowing their amplifier to be considerably cheaper (sometimes 50% less) to produce, yet they got to charge 90% of the same money as they did for tubes. As solid state improved and 4 ohms became practical, we saw a
big decrease in speaker efficiency, since building high efficiency speakers requires precision gaps and motor assembly (which makes them more expensive). All of a sudden much cheaper drivers (in particular, woofers) was possible. By using the voltage spec and promoting 4 ohm loads, the appearance was that the newer batch of speakers did not sacrifice so much efficiency.
In the old days when tubes were king, efficiency was really important because tube amplifier power is/was expensive. Today where amplifier power is inexpensive (500 watt amps are now common) efficiency is regarded by the industry as unimportant. These days 4 ohm speakers are far more common than 8 ohms. As an amplifier designer, I regard it as a bit of an epidemic, as the simple fact is that no matter what amplifier kind you have (tubes, solid state or class D) the distortion of the amplifier will be audibly higher into lower impedances, for example 4 ohms as opposed to 8 ohms. In high end audio, the goal is to get as close to the music as possible and 4 ohms flies very much in the face of that.
