SF woofer repair or replacement- help needed
eponies54
1
72
So yesterday my SF Concerto Domus woofer began to buzz. Checked mechanics and there is a rubbing sound of coil to magnet so am in need of rebuild or new. They are 6" Seas H1309-04 ohm. Cannot even locate this item on their site.
Please advise a solution and yes I have tried contacting local SF distributors already. Thanks in advance for the support.
Don in Georgetown, TX
analogsa
389
126
175
Cascais
Most likely the former has lost its perfect circle shape due to overheating. To fix is not a particularly invasive procedure and anyone in your neck of the woods who does speaker repairs should be able to do it. Your other option is a replacement from SF as the drivers are certainly different from the standard Seas.
