I don't know there has been no information about thatWhat is the upgrade cost?
Exterior and outlets look the same as previous so I assume it's all internal.....
just for kicks how exactly would you do that?would love to hear a blind comparison between an Everest and Everest-X....
Have an existing Everest 8000 and Everest-X on hand, then do a switch between the two....same tracks and same cords....as an end purchaser, I want to hear the difference before sending my Everest 8000 in for an upgrade.just for kicks how exactly would you do that?
FYI I replaced by Typhon/Denali with the Everest X. I was told by Shunyata when I got those pieces last year that they were virtually identical to an Everest in performance but easier for many to use since they fit on a shelf or a rack.
IMO there is a huge difference as I have already written about
fyi took me around an hour to do that in my placeHave an existing Everest 8000 and Everest-X on hand, then do a switch between the two....same tracks and same cords....as an end purchaser, I want to hear the difference before sending my Everest 8000 in for an upgrade.
I could do it here in about 10 minutes (everest is in front of rack)...that said, I know it's going to be an upgrade but I would want to hear the blind A/B before spending the cash.....the Everest 8000 is amazing....fyi took me around an hour to do that in my place
Hi Elliot,IMO this is one of the best audio devices I have ever used . I can't tell anyone that is a silver bullet or a universal fix but in my system I am hearing into the recordings like never before. When I am sitting at my desk outside the room the music truly sounds like there is someone in there playing the piano. My system has incredible bass resolution and integration and that is now at another level.
I believe that this product has done an amazing job of foundation power supply purity . FPSP lol a new term.
I am sure that those who have a really excellent system will go nuts over this because everything will just get clearer, more defined, more transparent, more you are there. I really notice that the system is far better than ever before at low levels, micro dynamics, low level images both front to back and side to side. The spaces between the notes is simply marvelous.
the unit has been on now three days , maybe there is more to come, maybe there isn't but for right now its the best result I have had.
What do you have plugged into the Everest X - front end, preamp, amps, subs?IMO this is one of the best audio devices I have ever used . I can't tell anyone that is a silver bullet or a universal fix but in my system I am hearing into the recordings like never before. When I am sitting at my desk outside the room the music truly sounds like there is someone in there playing the piano. My system has incredible bass resolution and integration and that is now at another level.
The EV-X replaced a Typhon and a Denali in the front end of my system. My Pre, DAC with 2 PS, Server and PS and Reiki switch with PS are all plugged into the EV-x and it is attached to the Altaira grounding system. So my entire front end of the system. IN the back end of the system I have the amps and subs ground again to the altaira and I used Typhon T-30 with the amps. Subs are directly into the wall with 20 amp power cords.What do you have plugged into the Everest X - front end, preamp, amps, subs?
Sigma 20 amp PC. I guess someday I will have to cough up the difference to try Omega X however my whole front is Sigma power cords except for the ReikiHi Elliot,
I’m wondering, are you powering the Everest-X with an Omega-X XC power cord or something else? Thanks.
I haven't spent any quality time with any of this, but conceptually I like the idea of the Everest specifically because it doesn't take up space on the rack.I was told by Shunyata when I got those pieces last year that they were virtually identical to an Everest in performance but easier for many to use since they fit on a shelf or a rack.
I like the Everest X design and have the space for it in my new room, the old room it really didn't work for me hook up wise. I am thrilled with what the new X does and I look forward to using them in some client applications, Visually it definitely makes a statement IMO.I haven't spent any quality time with any of this, but conceptually I like the idea of the Everest specifically because it doesn't take up space on the rack.
Per 34, how do you know the X is fully broken in to determine the differences?I could do it here in about 10 minutes (everest is in front of rack)...that said, I know it's going to be an upgrade but I would want to hear the blind A/B before spending the cash.....the Everest 8000 is amazing....
