Why?
The idea of moving on from my 28" Monoprice Monolith stands did not originate from any dissatisfaction with the quality of sound I was getting from the speakers mounted on those stands. As you can tell from what I've said before in my Dutch & Dutch 8c thread, I've found the 8c's to be near ideal sounding all along.
No, what drove this decision was the fact that the 28" height of the stands was, as it turned out, just a bit too high for my seated position in my long-term listening chair. I compensated for this by putting a couple of wooden platforms (an old Target Audio MDF rack shelf and a bamboo cutting board) below the seat cushion to boost my seated height more than an inch. While this was not really uncomfortable, it was not as comfortable as I know this chair is without this sort of "height augmentation."
Dutch & Dutch makes a dedicated stand for these speakers, but I wasn't keen on using it for a few reasons. First, at 24", it's a bit too low for my chair. (Similarly, the next lowest available height for the Monolith stands is 24".) Yes, I could put large tall cones or spikes beneath the stands and/or between the stands and speakers to raise the height. But I've not had good sonic experience with sharp cones or spikes under speaker stands in the past. While the bass is certainly tightened, it tends to go toward the anemic side while the high frequencies are, yes, more "detailed" but that detail often takes the form of increased treble and/or the treble is overlaid with significant "edge"/"grit"/"grunge."
And while I might try the A-V Room Service EVPs I like so much under my electronics under the speakers and/or the stands to gain extra height, I know from a lot of experience with the EVPs that getting the supported equipment truly level when supported by these devices is an exercise in frustration. The qualities of EVPs which make them great at absorbing vibrations—their compressibility—makes it difficult to distribute the weight evenly enough among the EVPs to get the supported equipment truly level, an aspect exacerbated by the fact that EVPs vary in height as much as 1/8 inch from one to another uncompressed by load. I've found that speakers must truly be as level as you can measure with a good bubble level to get them to sonically match left and right and create the most sonically cohesive sound field.
Second, the D&D stands seem wedded to cone-like spikes sold with them.
Third, the stands are metal and must be filled with sand/cat litter/rice or similar to deaden them, just like the Monoliths I currently use, a messy project, particularly in the winter in Chicago-land where the weather is not conducive to doing this outdoors.
Thus I Iooked for alternatives. A friend noted that Noel Nolan's Skylan Stands had a picture of a pair of D&D speakers on one of their four-poster stands in the Gallery portion of Skylan's website. The stand looked like it fitted the D&Ds like a glove—at least as well and as D&D's own stand—and it looked really handsome and well proportioned. The Website picture gives you a good idea, but I believe the stands are even better looking in real life than in the photo.
In addition I've successfully used Skylan stands twice before. Once was under my original Harbeth Monitor 40 speakers. And I also used a pair of one-poster Skylans for many years under the main left and right Totem Dreamcatcher speakers in the 7.2 home theater system in my old home.
Description
Contacting Noel I found out that he could make a four-post stand for the 8c's with any height between 24" and 27". The top plate would be 10.5" wide and 14.5" front to back, which matches the D&D 8c dimensions well.
He also was willing to take a stab at pre-drilling the top plates of the stands to match the D&D template for the bolt holes in the bottom of the speakers. D&D's own stands come pre-drilled so you can bolt the speakers to the top of the stand for ultimate stability.
Noel mentioned that in his experience bolting speakers to the top plate can significantly improve the sonics. He also is keen on using his Q-Bricks vibration mitigation devices (a sandwich cookie of top and bottom metal plates glued to a rubbery center with a tiny vinyl dot in the center of one side) with his stands as an interface between the speakers and stands. The idea is to place the Q-Bricks atop the threaded rod inserts in the stand top plate, vinyl dot side down to help with exact positioning in the well above the rod insert) to feed vibration from the speaker more directly into the posts and thence to the damped threaded rods within the posts.
No fill is needed or currently recommended for the Skylan stand posts because of these damped rods and the inherently low resonance of the polymer material used for the posts.
After further discussions with Noel, I decided to order a pair of four-post Skylan Stands for the D&D speakers in a 26" height. That height includes the hardwood floor glides which are mounted to the stand base. The price of the pair of stands was $570 delivered. Delivery took less than two weeks and from time of shipment to delivery was only two days, remarkably quick for what FedEx called its "economy international" shipment service from Calgary, Alberta, Canada, to Chicago in the USA.
The shipping weight of the stands was only about 35 pounds so they weigh less than half as much as my cat-litter-filled Monolith stands. They arrived intact and the packaging seemed bullet-proof. You can get an idea of the high level of packaging care by looking at the unboxing photos at this review from Steve's Blog. Assembly is even easier than it looks, is thoroughly covered on a single two-sided sheet, and was helped along by the fact that I've assembled Skylan stands before. The design is both ingenious and very good looking once assembled which takes only about 10 minutes per stand, I'd say. This process is much easier than assembling the Monolith stands, by the way, which themselves are not all that difficult to assemble. The Skylan parts just fit together so easily and positively; you know everything is extremely well seated and the parts fit together with a great precision which inspires confidence that you know you are doing the job correctly.
Description
