Smooth vs. Ribbed Plate Tele 12ax7s
Was wondering if anyone has done any comparison of the smooth vs. ribbed plate Teles in their gear. I've compared a variety of 12ax7s in my phono stage (Ampex, Mullard, Tele, stock new reissue Tungsol, Siemens dual post) but stopped at the rib plate Teles since they sounded so good. Should I have gone on to listen to the smooth plates?
Hi Myles:
I have compare the ribbed and smooth Tele's and many other 12ax7/5751 as input tubes for my Rogue Audio amp. This position is very sensitive to tube changes. At first I thought the ribbed plate was the superior tube--it just seems to have more detail and high end shimmer. Now I m not so sure. The rib can seem a little relentless at times, almost as if it is emphasizing the leading edge of the music . The smooth plate is, er, smoother. More even handed and flowing. Both are good tubes, but IMO (in my amp) neither is close to the best 12ax7. The good news for those who pay the high asking prices is that they are a very well made, long lasting tubes. I have collected over 2 dozen of them, and never had a weak testing one, or one with a large imbalance between the triodes. I have one old rib that was obviously abused, it has burn marks in several places but it still tests perfect. I believe these tubes have a 10,000 hour life span (at least).
Hi Myles:
Thanks! And welcome!
Thank you! Interesting place you have here........
Hi Myles:
Big welcome
Have you tried the Holy Grail of 12AX7's
the Tele NOS ECC803S. I stopped tube rolling after that tube. A small fortune if you can find an "authentic" matched pair but good news is they'll go 10,000 hours
Hi Steve:
No, I have never tried the Tele ECC803s. And unless I get unbelievably lucky at a hamfest someday I probably never will! This will make you feel good--some say the Tele 803 were spec to last 100,000 hours!
Best 12ax7's I have heard in my amp in no particular order:
Raytheon long black plate square getter 1950's
Raytheon long black plate round getter 1960
Valvo/Phillips I60D code short plate 45 degree tilted getter (have not tried the long plate version)--MUCH better than the common I65 "bugle boy"
Matshushita short-plate 45 degree tilted getter
Siemens long plate double getter support mc6 code
Tung Sol square getter 12ax7
Also have a soft spot for Raytheon windmill getter 5751 and Tung Sol 5751
Roll on!
Steve, have you tried them against the EAT ECC 803's? Best I've tried so far are the Ei12Ax7 gold pins for the overall.
Well until you hear the Tele NOS ECC803S with the diamond insignia on the bottom with or without the gold pins you might be pleasantly surprise. I don't do any other tube rolling other than that one tube
803S guy myself here. Jadis (the member not the company :) ) helped me source two matched and balanced pair. I use them in my phono stage.
Jules Limon of EMT ships the PR-66 with JJ Tesla 803s. In his opinion, if you were to change tubes, the only tubes he would recommend in good conscience are the TFK originals. I can't say I disagree. My phonostage was shipped with JJ's too and they were very good. The TFKs however are in a whole 'nuther league.
Hmmm. Now I'm getting itchy to tube roll my amps. Out go the CV2492s and in go the TFK redtips tomorrow :)
Steve, you should try some of the tubes on my list before you declare the 803 the best ever. Some people seem to think they are only slightly better than regular Tele's. I don't know, never tried the 803 but do know that high price/big rep. don't always mean the best. The tubes I mentioned are not household names like Amperex or Mullard and don't come with the big rep, but they are truly outstanding and known to the true 12ax7 connoisseurs out there.
Never hurts to try.
I have never heard the Telefunken ribbed 12AX7's but I own the smooth plates. From what I heard from others they almost sound alike. I like Telefunken but I prefer more warmth. I use GE five star black plate 5751's. Not quite the soundstage size of the Telefunkens but warm and musical. You have to be carefull with 5751's because they don't have as much gain as 12AX7's. A serious rival to the Telefunken 803s would be the Mullard 10M 12AX7's. If you want the 803S with more warmth the 10M might be for you.
