Is that something used to fill cavities in with to dampen resonances?
About 20 years ago I filled the hollow cavities in the plastic plinth of a Dual CS 503-1 to good affect with DUCT SEAL from a local hardware store. It is still pliable.
Like this:
https://www.homedepot.com/p/Ideal-1...Jck7kwi1Yob3zK9QuXOdcnhDTqguEfXhoCCcIQAvD_BwE
QUOTE:
Product Overview
Designed for sealing in and around electrical conduit
Creates barrier from air and moisture
Non-toxic, soft compound can be painted immediately
Ideal 1 lb. duct seal in dark gray putty color is Ideal for sealing metal, masonry, wood or plastic. It offers 1.65 specific gravity and is non-toxic. It has calcium carbonate, magnesium aluminum silicate, crystalline quartz silica, butane polymer, synthetic polymer, carbon black, antioxidant, cellulose fiber, aluminum silicate, tall oil rosin and naphthenic wax composition. Duct seal is UL listed.
Moisture and air barrier
Seals around junction boxes, flashings and service entrances
Permanently soft, non-toxic compound can be painted immediately after application
Won't adversely affect other plastic materials or corrode metals
Info & Guides
Product Overview
Model #: 31-601
Internet #: 300496860
