Yeah it's like guys getting divorced and remarrying the same type of woman and getting divorced again![]()
Like "same inferno, different devil" kind of?
Like "same inferno, different devil" kind of?![]()
In the Western musical scale, there are 7 keys in an octave. Adding the 5 black keys, you get 12. At 1/3 octave smoothing, you are losing more than 75% of the actual resolution needed. Speaker designers use that fact to "voice" the speakers and still achieve relatively flat 1/3 octave response.
Gary, could you please elaborate a little more on how this knowledge is utilized by designers and presumably by you as well.
Hi DaveyF,
I think speaker positioning is very much a matter of preference.
However, this should not be confused with optimal speaker positioning for best performance from the speakers. ;-}
Some folks just don't want their speakers "in the middle of the room". Those who claim "more bass" from positions close to room boundaries are confusing bass in the program on the recording and resonance of the enclosed space in which they listen. They are getting more *room*, not more bass as the increased low frequency levels have nothing to do with what is on the record; they are simply making the room "ring".
People seem to understand it more intuitively when video is involved. Place a video projector somewhere convenient and "out of the way" and the video won't be very good. You won't see the projector if it is in a closet - but you won't see much video either. ;-} Place the projector in a corner and aim it at the middle of the screen and the result will be a skewed image most folks wouldn't want to watch.
It seems far fewer understand that in audio, the speakers are the "projector" and the room is the "screen". Hence we get skewed images and compressed sound stages, if they're in focus enough to discern any images or a soundstage at all. We have folks thinking in terms of frequency response (are the colors equally bright?) but not in terms of temporal response (is the picture in focus?), etc. etc.
As we've all experienced in one place or another, issues of preference arise which may not necessarily reflect preference for the most neutral portrayal of the recording. Sometimes they involve preference for a certain look in the room decor. Often the room is furnished before the speakers arrive. Not that many have the good fortune to decide on speaker position *first*, then arrange everything else in the room around that.
Best regards,
Barry
www.soundkeeperrecordings.com
www.barrydiamentaudio.com
Hello, John. That may qualify as a matter of preference. I've tried both in a room that size and some folks who observed both systems preferred the monitors while others preferred the floorstanders. Personally, I preferred the floorstanders but I have to be honest. The monitors offered the edge on imaging and less resonance.....while at the same time, less of the lower frequency output [weight, authority, impact]. I think your question might be an entirely separate discussion worthy of its own thread. There are many variables to consider.
Tom
Great post!
To add however.......sometimes (as in my case) its an issue of not having a lot of choice. My room is really small at 10x11 so speaker placement options are extremely limited. This brings to mind a question! Would I be better served with a nice pair of good quality monitors as opposed to floorstanders? ( I am using Totem Sttafs)
Hi John,
In my view, a smaller room just means optimal setup will involve a smaller triangle between speakers and listening position - and a smaller soundstage as a result. While it might suggest avoiding very large speakers, it should not dictate the *type* of speaker.
For example, I've heard MMGs in small rooms, which I felt quite easily outperformed some considerably more expensive speakers in larger rooms.
Best regards,
Barry
Thanks Barry!
After trying several placements I've found that the speakers placed in a perfect equilateral triangle works best (in my case, with my speakers). I know I am losing some soundstage or imaging (these are two descriptors that I constantly confuse).
If you want the best of both worlds (imaging and bass) use a separate sub(s) then place mains and subs where each gives the optimum performance!!!
Great post!
Yes Ethan, BUT that would seem to assume that most/all listener's are seeking accuracy. I'm not certain that this is the case. Additionally,some would argue that accuracy is a variable, determined by the particular listener's expectation of what the 'real' sounds like.
