Stock First Watt F4: Complete Distortion Measurements?
ajant
72
5
138
I count myself very lucky to have this amp. But AFAIK, the stock First Watt F4 never got put through the wringer the way the J2 did. https://www.stereophile.com/content/first-watt-j2-power-amplifier-measurements
And unlike the J2, no distortion measurements were included in the F4’s manual. Here's some ("quick and dirty?") distortion measurements from 6L6's first build of the F4 build, post #2.
https://www.diyaudio.com/community/threads/a-guide-to-building-the-pass-f4-amplifier.234355/
Okay, so even a stock F4, like I have is probably not a low distortion amp. But my speakers are ~ 94db/w, they don't fall much if at all below 7 ohms and only play down to 70Hz, below which my Rythmik F12 subs takeover.
So, with a line stage like the Aikido Rev. F providing plenty of gain
https://glass-ware.stores.turbify.net/ainost.html
https://tubecad.com/2018/03/blog0415.htm, how much 3rd or 2nd harmonic distortion would the F4 produce which would likely be audibly offensive?
Well, what happened was that Grovergardner here drove me to pursue the SP14 version of the Aikido. https://www.diyaudio.com/community/...or-less-than-great-sounding-cds.408331/page-4 I found that here.
http://www.tubes4hifi.com/pre12.htm#SP14
But after learning earlier that Don Sachs was working with Lynn Olson to co-design Lynn's new no-compromise 300B p-p amp-and then after reading Don's praises for Roy Mottram's SP14, I then when to check out Don's version.
Emailing Don about optional upgrades, I was told that the Sachs # 2 preamp
was now discontinued. I was about to search for a used one when I found a link at Don's website to his new preamp. https://www.spatialaudiolab.com/revelation-preamp
While I was less thrilled with its range of output connectivity and overall aesthetics, everything about its circuit design and parts quality and price makes choosing it pretty much of a no-brainer to drive the F4.
Reactions: cpcat
