T-2000 25th Anniversary
matakana
304
142
50
59
UK
The T-2000 25h Anniversary - has a 8 Ohm 4 Ohm switch - set to 4 Ohms and the KT150 will drive these speakers without issue. There is no parasitical crosstalk between the windings (4 Ohm/8 Ohm) since they both are used simultaneously.
I actually adore the Kron tube sound but have not heard anything about a KT170 - I would love to hear more about them.
Another aspect of the Allnic T-2000, you can adjust them later and add in a preamp by bypassing the internal preamp. This adds future versatility and allows comparing to the internal preamp circuitry.
Hello Ketcham
Could you elaborate on the above, Can you also use it as a preamp to other poweramps, if so can you remove the power tubes as they would not be required?
ketcham
174
116
150
Opposite. Use external preamp.
matakana
304
142
50
59
UK
Can you give us an update? How is the KT170 different from the KT150 in the T-2000?
If you look in the vacuum tube forum here and scroll down to the Tung sol KT 170 have landed, you will see further info.
I have close to 300 hrs now and zero issues, These are much more lower colouration, quite superb sounding!
Stevereds
1
2
68
62
Stephen here from Soul to Sole Audio in New Zealand.
I distribute Allnic Audio here.
My first T-2000 30th Anniversary arrived last week and I have been demoing to customers and the shops I supply.
Here is what I posted onto FB after hearing this in half a dozen different systems in the last couple of days......I am besotted with this amp and have immediately ordered more....it is "next level" musical!
"This Allnic T2000 30th Anniversary amp is ABSOLUTELY the finest sounding amp I have ever imported. The 120watts in Pentode sounds fantastic but the 60watts in Triode mode is sublime......music enters your ears and seems to bypass your brain and goes straight to your ❤️.... it just sucks you in emotionally.....NZ$23,500 and worth every penny and more..... don't demo it unless you can afford it...."
