What are other owners using to put under the TAD ST2TX, has anyone not bolted their CE1 to the stand and used some form of isolation base/feet between the speaker and stand?
Has anyone tried WellFloat/Stack Audio or Track Audio?
We will evaluate Wellfloat Delta and Franc Audio Ceramic disc hybrid feet here very soon in Stockholm under the TAD CE1TX stands, I would be happy to report back in due time.
Yes, that's certainly a possibility and option as well. We've got quite a few options here to play around with from Wellfloat, Franc Audio accessories. HRS and Arya.
Fantastic can’t wait to read your comments after your testing. I have been considering Wellfloat Delta as isolation feet to go under the stand and the Delta Extreme between the speaker and stand. Will hold off doing anything until you guys have done your tests.
I expect that a combination of four stable feet in between the speakers and stands combined with a set of Wellfloat Delta or Delta Extreme in between the stands and the floor to work well. But let's find out
I'm using stacked audio AUVA 100 for my CE1TX on concrete flooring. It tighten up the bass nicely. I also like that I can adjust the speakers much easier than spikes or other footers.
