Hi Micro
Yes there are a lot of parts in AF tables. The bulk go into the vibration management aspects of it and the others are for ergonomics.Particularly with the 1s and now the zero, you'll find work inside that anybody who loves seeing fine machine work will likely never see. The attention to detail isn't skin deep, it goes to the bone.
Some aspects of the vibration system design philosophies and engineering choices require these pieces. The vacuum system for example does double duty. On the surface it looks like all it does is help flatten the record. In fact the use of vacuum chambers inside the platter to disrupt and damp vibration travel is a key element of why the tables are so quiet. This is easily demonstrated by comparing the groove noise levels between program material. The Zero has multiple platter sections with different materials for CLD and also as a way to add more of these vacuum chambers. The upper platter is made of Tungsten Carbide and alone is extremely expensive to make because it is sintered and not cast or forged. It is chosen because the molecular structure can be manipulated in the sintering process. The bottom most section is much larger in diameter to both increase the area for air to support the massive platter and also adds a flywheel effect for speed stability.
The conical vertical component does not have contact as has been assumed (even by mysel)f when set up correctly. There is an airgap too.It is in fact where air is supplied and this flows down under the platter to lift it. When there is contact, which happens when the belt is too tight, the friction inhibits the motor from reaching 45 rpm during the microprocessor aided calibration process. This in turn required a belt tensioner system like that on fan belts to make tension calibration easier as the alternative would be to make fine adjustments by moving the entire (heavy) motor assembly relative to the main plinth. When setting up the tension, you look for the point where you just remove the ribbon flutter and no tighter. This ensures the best centering which sonically is also the most smooth and free flowing. Think rim drive contact pressure or idler clutch settings as an analogy with regards to friction.
Then there's the passive air suspension which is augmented with the thoughtful addition of parts (worm drive) that allow you to level the table from the top while you look at the bubble level incorporated into the control panel. As the arms are mounted directly on the top plinth instead of outboard pods, there are no pods to level (except the motor's) when changes are made or when set up on a less than ideal surface.
It takes me around 45 minutes to set up an AF1 including an arm beginning with unboxing. In extreme contrast, my best bud Phil (Jadis here on WBF) got the fabulous sounding top dog LP12 and by his account the dealers still weren't done six hours in. It's a great story and the results were worth it. Best he tells it himself though. Especially the part where a special table/jig has to be used because the unit can only be worked on from underneath. This set up time is comparable to my set up time with the AC-3 which actually takes longer because of the 3 motors and my HRX because of the multiple belts that seemed to have minds of their own. A lot of the time saved on the AF3 is in the speed calibration which no longer mandates an outboard strobe and strobe disc. No need for extra tools to access trim pots like in some CA models and no speed surfing as calibration is saved to memory and will adjust to power conditions.
During everyday use, it is as simple to operate as my Technics SL 1200 family turntables. No bending over to reach for a control box that may not have fit on the same shelf.
It is complex but the complexity is there towards not just sonics but high levels of ease of use. They recognize that time, our time, is valuable. I call that considerate engineering. I suppose some audiophiles like hustling and bustling about like Victor Frankenstein in his lab, perhaps with an Igor in tow to boot. No mad scientist behavior required here.
