Technical Article on Capacitor Heating
DonH50
Jun 22, 2010
3,968
326
1,670
Monument, CO
amirm
Banned
Apr 2, 2010
15,813
38
Seattle, WA
Thanks Don. I am reading through it but it is hard to follow with the fuzzy text and such. What does this graph mean for example:
How could the Vcap have a range under the curve???
DonH50
Jun 22, 2010
3,968
326
1,670
Monument, CO
Aluminum capacitors have a pretty large temperature coefficient (tempco) so the graph is meant to show that, if you start in a cold environment, the value can change a lot as everything warms up to normal operating temperature. You can buy special versions that are more temperature-stable, and other types of capacitors that do not vary so much with temperature. A lot of capacitors also vary in value with applied voltage, which can do strange things if you aren't careful in your design.
