Does anyone know of any downside to having a plinth built from a billet of aluminum? It will be strong, dimensionally stable, and non-resonant.
Mark, I wonder if making it out of solid cell-cast acrylic might make it sound better than aluminum and be cheaper too? I'm not a big fan of metal (says the guy who makes all metal-coned loudspeakers).
I have been contacted by George to look at your SP-10II "plinthing" problems!
Funny enough,lately a friend of mine has asked for my opinion on exactly the same project!
So you can say that i have already formulated some thoughts about how i would make such a project.
I would suggest a metal chassis with layers of aluminum and bronze or leaded iron.
I would certainly put the arm on a separate plinth (a rectangular base alongside the main chassis) that could be arranged
to look "identical" to the power supply so that it could produce a "symmetrical" looking design.
Different metals have different resonant frequencies so a sandwich construction (with a little extra dampening) could be a good step towards making a "dead" plinth!
I would follow the same route for the tonearm base...With a design like this the tonarm base will be VERY heavy and rock solid!
My friend is considering this solution or a "panzerholz" design...
Problem is the cost!
Perhaps you could contact some local CNC shops and ask for prices.
I don't think that it would be any more expensive that the "boutique" wooden plinths that you are considering!
I'm a big fan of the KISS (Keep It Simple Stupid) method, but do plan everything through.If Magico can make an entire large speaker enclosure from billet aluminum and not suffer resonance problems,
