Well I can just talk in a bit more detail about my discoveries with DACs and hopefully you'll be able to relate that to your own experience with what's commonly called 'detail' and make up your mind accordingly.
At first listening to my TDA1543 DAC I really missed the detail which was so evident on the S-D (AD1955) I'd had as my reference. Missing the detail meant no 'spotlighting' of the front of stage interest any more, less 'focus' on vocals. I must admit though that there was always something alluring about the timbre of orchestral instruments with NOS, but for me the trade off wasn't sufficient for me to pursue NOS development seriously because of its lack of soundstage. Then one day I experimented with the output filter on my TDA1543 and made the soundstage come back - not to the same extent as with the AD1955, but perhaps 80% as good. Only then did I start to think that maybe NOS DACs had a future.
I started with TDA1543s but from the measurements was convinced that TDA1545 was the better DAC, technically. It has 'continuous calibration' to ensure the bit weights are accurately proportioned, but when I tried it, it didn't sound as good. It hadn't got the 'organic' quality of the TDA1543 - what was actually happening though was it was adding 'detail' - and by this time I'd listened to TDA1543 long enough that I was totally weaned off detail in favour of 'organic' and accurate timbres. So when it came back, I wasn't a fan and wondered if I could get rid of it and make the TDA1545 sound more 'organic'.
It turned out the answer to this question was 'yes' - the solution was ferrite beads, lots and lots of them (30 or so). A very long string of ferrite beads between the TDA1545 and the amplifier (using passive I/V in between) got rid of all that detail and made the TDA1545 sound considerably better (as measurements predicted it should) than the TDA1543. The ferrite beads were absorbing all the excess RF energy (glitches) produced by the TDA1545 which weren't coming out of the TDA1543 because this latter chip is a bipolar one (not CMOS). With this discovery, I was satisfied that this is the reason DIYers have shied away from the TDA1545 in favour of the SQ of the 1543 - they were looking for the 'organic' sound and hadn't cottoned on to the reason the 1545 sounded poorer in this department - glitches.
Does any of this help?
