Why I have Fiber Optic...... enjoy your wi-fi...
I have wired and wireless. And I gave you the list of DACs, which you might note do not have wireless ethernet connections on them.
But you didn't read it, because, oh.... well...... you just want to ignore me... but ultimately, my point prevails.
1600 feet of CAT5e. Did you miss that?
I also run SFP between my three backbone switches, the NAS are wired directly via GigE to one of the switches. The whole thing is optimized. Connections are all done with the best wires I can get off eBay, no
Wisdom in my
Cables, Not cheap wires, mind you, just good electronic and mechanical connections. Besides, I do my own terminations.
Did you run the entire LAN with fiber? I doubt it, unless you have an extremely simple LAN. How do you take the data from your network storage to the DAC? How do you wire your Internet music servers to your DAC?
Heck, using Perfect Bit, I can get my Android devices to drive the DACs via USB-OTG to 24/96 and 24/192. Over many years of recording my own LPs, I found out that 24/96 gives me an almost perfect copy of the recording. Of course, then I change something in the analog chain and.. well... I take care of my records and use Internet distros at 24/96 nowadays. Some at 24/48 (hoping the Chromebooks fix that one of these days).
My power distribution to the house...hmm.. .well, we rebuilt the entire house, with a 300A box. Lots of dedicated circuits. Main stereo has two homeruns, HT has another two homeruns, hospital grade outlets. No ground loops, no noise, no hash... clean power. A fundamentally good design with no need to patch things after the fact.
No fancy names, just really good wiring, 30A Romex in the walls.
BTW, let me ask you a question.... have you ever programmed a USB device... like, write a device driver for it. You know, where you sit with a bus analyzer for months on end to ensure that you can buffer the data correctly? Worked with the hardware guys?
Have you done internetworking design and programming work? You know, writing stacks, testing networking hardware gear? Being in the business of companies that design internetworking gear?
Have you done audio/video/data IP based distribution? I was doing that in the bad old days of the early 90s, before we had HTML even.
Once you've done that, you don't need to fancy sounding Reference Mk II wires or switches.... it doesn't make a difference when both sides of the data link connection are properly isolated in time and ground. A clean connection, with low noise at both ends, with decoupled clocks and RAM is all you need to communicate data. It works for video as well. Which is a much larger data pipe. Again, asynchronous connections, with separate clocks and low noise.
There is no need for your
Uptone EtherRegen, Sonore OpticalModule Delux.... My stuff is not
Ultimate, I guess I have not reached the end point. I mean, if it rocks your boat, so be it, but don't expect everybody to believe you.
And mind you, I'm as anti ASR as they come. I love negative 2nd order harmonic myself. But when it comes to digital communications, well that one, it's snake oil. Many audiophiles, even the ones that know the in and out of analog electronics ( not the marketing, the actual engineering part of it ) don't always realize this.
Any how, I got lots of systems at home... to list them would take a long page.... not many fancy names though, just a collection of DIY and commercial units with rather plain names and numbers. None of my components are
Legato, Zenith, Sonore... No Multicancione Audiobiliti Nervosa Molto Excellence stuff, I'm afraid... Just a bunch of numbers, F4, F5, Aleph 2, Aleph 5, SIT, MF21, D70, ST200, P3, P7, A8.... rather plain names I'm afraid don't give me much power in the bragging dept... but the sound is fantastic and my electric bill is heroic.
I think Tony22 above would recognize my systems by the components that he listed.
Anyhow, the sound in my house may not be called "
Delux" but it sure sounds deluxe enough. And my Intranet components are solid professional units.
Oh, yes, I forgot, did you get how I configured my access points to be a DIY roaming system? Not hard to do if you know how to configure the boxes. Otherwise, well, you can go spend 1000 bucks for some fancy boxes.
