If you have a macbook or any computer you should be able to stream direct to the MSB renderer from the Qobuz windows or macos apps using UPNP/DLNA.
Or Roon.
Or Roon.
Hi RonThank you, Jimmy and Dr Tone and Alex!
Hi Ron
I use the Bluesound Vault (a node with built in hard disk). I stream Qobuz and the sound quality is very good fed into Kassandra or one of my other Dacs. It is hard wired into my router (it doesn’t connect wireless to the network but is controlled through an ap on my Android tablet).
What do I need Bluesound for if I use a streamer?
1) Ethernet cable from your router to Bluesound (node or vault)
2) Digital out (coax or toslink) to your dac..or rca interconnects to your preamp but you can bypass Bluesound volume control
3) download iOS or android app (free) for music selection
Not through the Renderer. You'll need to output USB via the server of your choice.
I respect of your choice of not wanting Roon, but I don't understand itIt does bring you back at least 2-3 years in terms of ease of use.
[QUOTE = "asiufy, post: 563302, miembro: 1550"] No a través del Renderizador. Necesitará la salida USB a través del servidor de su elección.
Respeto tu decisión de no querer a Roon, pero no lo entiendo.Te hace volver al menos 2 o 3 años en términos de facilidad de uso. [/ QUOTE]
This has been a surprise for me. I thought that the MSB with the render module would work the same as Lumin, which is a DAC with render, and does not need a server to play Qobuz.
One of my all time favorite SACDS. That song in particular is amazing at loud volumes.
Here is the simplest way to try it out (for about $50 total):
1. Buy a Chromecast Audio (CCA). They're discontinued but available at certain places:
https://www.mobilefun.com/google-chromecast-audio-black-70476
2. Buy an optical out cable for the CCA. The CCA has a port that delivers both an analog out and an optical out. You'll skip using the analog out in favor of getting the digital out via the optical cable. Unfortunately the CCA only does optical out so useless for you if you don't have optical in on your DAC or a converter. You can always use the analog out but a good separate DAC will obviously be much better.
https://store.google.com/us/product/optical_cable_chromecast_audio?hl=en-US
3. Open up Qobuz (or Tidal) on your iPhone and cast to the CCA.
