To SUT or not to SUT?
I think it is instructive to see the specs of the cartridges Tom (Montesquieu) say's work best with his SUT's and compare them with the specs of the cartridges he is using with his head amp. I am inclined to think that most cartridges with "modern" specs (for example 0.5mV output, ohm impedance like the My Sonic Labs) will work best with a head amp whilst cartridges with "older" specs (like the FR-7 or Io 2 above) work best with SUT's. Most of my cartridges fall into the latter camp but I do have a few of the former and find that whilst they do work with my SUT's they need more experimentation with their loading requirements for best sound.
I think it's mainly down to output ... many older MCs are of very low output, which pretty much always respond better to use with a SUT. (It being just too much to ask a valve in particular, but also most implementations of FETs, to provide sufficient gain to boost them to sensible levels without introducing too much noise.)
SUTs can have their own noise challenges though ... I've learned over time how to set up arm and turntable earthing, as well as appropriate system layout and interconnect selection and dressing, in order to get them dead quiet, but I recall years of difficulty with ground loops or induction hum.
Per the original question - a healthy 0.5 mV at around 1 ohm, that's right in head amp sweet spot, even a tubed one like the HA5000.
Reactions: wbass
Having myself an Allnic H3000V, I had considered getting their head amp as well but the output of my cartridge is too low and I went for a custom made SUT from Consolidated Audio. It was definitely a big step up compared to the Allnic's internal SUT.
Reactions: bonzo75 and wbass
Yes to SUT!
I am using Phasemation pp2000 and a MSL sig. is on its way.
I didn’t believe in SUT until I heard a good one, now I have 15. All vintage though, hard to find newly made ones that are as capable and I have heard some of the most renown ones.
I used 1:15 for Phasemation and that works well. 4.5mv output works well in my System. Using full range no crossover. I do not ‘load’ the cartridge, leave it as 47k fr the phono. If u do the maths any impedance less than 20ohm made v little difference to the gain.
Using the right SUT gives a more open, natural sound. And more importantly the tone and timbre. Unfortunately there is no one SUT fits all. Matching the cart and SUT is critical. Try not to overground the SUT either.
That’s why SUT route is a rabbit hole, they multiply!
Have you heard your Phasemation pp2000 through a pair of Phasemation T-2000 SUTs yet?
I have been an SUT enthusiast over many years and owned quite a few - AN S6c (Kondo era Audio Note), AN S4 (ANUK), Paravicni The Head TX4, Hashimoto HM7, Stevens & Billington TX103, EAR MC3, Audiorium A23 SPU version, Miyajima KSW, Altec 4722, UTCA12 and quite a few others, most recently the multi-adjustable Miyajima ETR-Stereo and ETR-Mono SUTs, and of course the internals SUTs in my Allnic H7000V and in my previous EAR 912.
I would still consider myself an SUT enthusiast in many circumstances but I had quite a change of opinion when I heard an Allnic HA3000 head amp in my system, after which bought my own HA5000 head amp (the HA3000's replacement, with inputs for two tonearms rather than one). This is way better than any previous head amp I've tried, valve or solidstate.
Anyway, in the months since this arrived I have since sold the Miyajima SUTs, and use the HA5000 with (among other things) a pair of My Sonic Lab cartridges, a Hyper Eminent and an Eminient Solo mono (see my previous write-up here https://www.whatsbestforum.com/thre...-104s-and-mh-124s-tonearms.31616/#post-683539
Hopefully this direct experience of running MSL cartridges with head amps vs SUT might be useful, I don't know the OP's phono stage but can say that the Allnic pairing (HA5000 head amp and H7000V) works superbly with these cartridges and I have no intention of going back down the SUT route. Which is something I would never have expected myself to write.
Montesquieu, would you kindly tell me about your Leben? I own a CS-300Xs that did not sound good until I removed the Sovtek valves that it came with (they used to come with Mullard EL84's but as they became rare switched to Sovtek, hence the s on the end of the designation) and replaced them with NOS Amperex. My Phasemation pp-2000 MC cart goes through a Phasemation T-2000 SUT pair, to a Leben RS-30EQ valved MM phono stage. The output of my CS-300Xs is only 20 watts, push-pull I believe, but my speakers (Thrax Lyra's) can take up to around 250 watts. My system sounds great, but if my CS-300Xs should ever fail me, does your Leben have the magic? Did you have to change any valves? Thanks,
I've owned quite a few EL34/KT88/90/120 push pull valve amps over the years including the Leben CS660P, Radford STA25 (which is 35w EL34) and Radford STA100 (100w KT88) - the latter restored for me by Radford Revival in the UK - as well as EAR 890 and assorted others.
My take on PP amps is generally that single pairs of pentode/tetrodes per channel sound better than parallel push pull, where in return for more power, you risk clarity and coherence. For that reason I wouldn't go to parallel push pull, even though I've heard a few PPP amps that I quite like (EL84 based, typically). It's also my view that pentodes/tetrodes should be left in standard configuration - I never really heard a triode-strapped pentode that pushed all buttons for me, especially in an amp that's switchable, as opposed to needing physical rewiring.
The Leben CS1000p for my money is right up there with the very best KT88 PP amps out there. It comes as standard with KT120s. I'm not a big fan of KT120s generally (they always sound a bit 'thick' to me - I dont know whether this is a particular characteristic of the Tung Sol design) so I put in my favourite tube - the EH KT90. Just as powerfull in the bass, at higher registers it has more clarity and a share more musicality in my book. But then again I'm biggest on Renaissance and Baroque chamber music, Lieder and solo keyboard. It's possible a rock fan may go the other way. As mentioned I always run it in pentode - in fact I don't even know why they bother with triode switching.
Anyway for my money the 1000p is less compromised than the 660p which is a sweet and lovely thing with plenty of bass - but the bass is soft and less defined in comparison to the 1000p, which really is a different animal - it's larger, beefier all round and has a more robust feel to it. In absolute terms the 1000p it hasn't quite got the grip of a high-power solid state amp, but the counter-side is that it retains a sweetness common to the Leben line.
I guess what I'm saying is that it sounds like a valve amp, but a very good valve amp. If you are seeking to move up in power from elswhere in the Leben line it could be a good bet. There is a review out there where someone (cant remember who), who has also owned both, came to a verdict the CS1000p, while more accomplished in every normal hifi criterion, somehow lost out on magic to the CS660p .. well having also owned both, I simply don't agree. Not with KT90s in anyway. For me it's simply better all round, period.
As ever, I suppose it depends on speaker-amp synergy. But hard to see where you can go wrong.
In part just for the sake of change, I've been quietly eying up different options, such as going OTL, or going back to Radford STA100 or STA100-derived monoblocks (the Radford is even more robust in the bass than the Leben, indeed in many ways sounds more solid state than valve - though my Audiopax Model 5 pre enables me to dial back in some of the valve juicyness).
But it really would take something special to knock the Leben off its perch. It's such a lovely looking, well made thing too - a pleasure to own.
Hi
I am also looking at low impedance/low output mc cartridges and SUT and have been reading a lot about both lately. The one that seems to consistently get the most rave reviews from all that hear/review them seems to be the Auditorium 23 Homage T1. Art Dudley thought it was so good he felt it deserved a whole new category and gave it a class A+ (as apposed to just class A) in Stereophile magazine's "recommended components" list which is very unusual for him especially. It's expensive at $5000.00 (what in this hobby isn't) but he claimed it was just amazing. A lot of the manufacturers who build these cartridges also offer their own SUT that's usually made specifically for their cartridges. That might be a good option. Good luck.
Hi everyone
There seems to be a lot of talk on this thread about phono stages rather than just SUT's, and I thought I'd flag that I'm in the market for a 240v used Allnic H7000V. PM me if you have or know of one in the UK.
Apologies if this isn't where I should be raising this request.
Thanks
Wayne
The question of whether the use of SUTs makes sense is as difficult to answer as there are different SUTs and systems.
Ultimately, you can only try it out and decide individually. There are plenty of good tips here, so that at least a direction is given that you can orientate yourself by.
We have had very good results with Phasemation T-550. In combination with Ortofon's SPU, the T-550 makes 1:20, i.e. 26 dB gain. The two harmonise excellently. The very full-bodied and rich sound of the SPU is fully preserved with depth and precision in the bass. The room/stage imaging is almost holographic. All we decide by ear. CSE is excellent.
My experience. It is not a qeuestion of tube or no tube. We heard it with tube and Solid state phonostages. Both win equally.
groovemaster
Reactions: XV-1
A 10x transformer will provide 20dB of step-up or 5mV rating, which when coupled with a basic MM input of 40dB will provide a total of 60db of gain. The transformer will also transform down the 47K MM input resistance to 470 ohms which will be a good match for the MySonic cartridge.
The suitability also depends on the overall amount of gain in the system. MSL’s own SUT is 26db of gain, which is more like a 1:20 ratio. In my setup I found the MSLs were happier at this higher ratio using the internal SUT on my H7000V (though I actually use it with the 29db / 1:30 H5000 Allnic head amp, which of course is a different beast with different considerations).
Interestingly the matching SUT of the very closely related Murasakino Sumile (clearly an evolution or variant of the MSL cartridges) is also 26db.
As always with SUTs, however many calculations you do there’s always an element of suck it and see. 1:10 might work well in some set ups but I’d be prepared to check out higher ratios too.
It seems some like them and some don’t, or just prefer the sound of a more complete phonostage.
I’ve recently purchased a My Sonic Labs Gold cartridge, following Shakti’s interesting journeys through analog.
Anyway, I’ve connected it to my XP-25, set the impedance to 500 (in the recommend range) and using the 66dB gain settings.
It sounds really good, and my DS Audio W2 is getting some bench time at the moment.
However, the specs says the Gold outputs a mere 1.4 ohms, this is usually SUT territory, and even though I’m happy with the current end result I’m curious to try a matching SUT and hear what it does.
Immediate suspects are:
1) My Sonic Labs 1030
2) Phasemation T-1000/2000
Thoughts, suggestions and opinions are welcome!
I apologise if someone else has mentioned this before. Your 'My Sonic Labs Gold cartridge' has an ultra low impedance which means in practice a high current output. If you switched to a current amplification phono stage like the one from CH Precision or others like Channel D etc this would be a match made in heaven. Michael Fremer uses the CH Precision phono stage with excellent results I believe. DONT make his mistake though and use adaptors - RCA to XLR - on your tonearm cable as this largely negates the point of current amplification.
Reactions: McDee275
Sincere question: Why is this so?
Can someone explain the voltage/current comment for an electronics numpty like me? As I mentioned I'm getting my results here from an Allnic HA5000 head amp which uses a pair of Nu-Vistor tubes.
At the moment, I have access to the similar, but excellent, Air Tight Opus 1. I first tried it with the Ortofon ST90 (24 db gain about 16 turns ratio) which is the best match, among my several options, for my Ortofon Anna. It was not a great match for the Opus 1. I then used the Luxman EQ-500 internal High transformer (about 19 db gain and 9 turns ratio) and experience a much better match with a total gain of 19 + 38 for the mid value MM gain = 57dB. This feeds a line level input of a Levinson 32 preamp which is very quiet and is just fine. The higher gains may be desirable when using tube preamps which may be noisier than a good solid state unit. In this case, the higher turns ration will result in a lower effective impedance and, to my taste, sterile sound quality. It's all a trade off isn't it?
It depends on how the rca to xlr is wired. If it is an adaptor made to apply a signal to 1 phase and ground the other, then it won't work properly. These would tie the rca outer and inner contacts to pins 1 and 2, and short 3 to 1.
I believe there are adapters (or cables) which tie the rca outer and inner contacts to pins 2 and 3, the shield/ground can be applied to pin 1.
The latter configuration can also be used for inputs which drive a differential input pair where neither input pin/contact is tied to chassis ground. An ohm meter is useful for checking all of these.
An SUT provides additional gain for very low output cartridges, but no RIAA equalization. The latter requires a standard MM phono input or stage. You can't use an SUT by itself to feed a regular line level input.
Hi everyone
Thanks
Wayne
I
If you are going to use a SUT into an MM phono stage, whether tube or transistor, the most important thing to get right is the SUT has the correct level of gain to match your cartridge to your phono stage. Example: if your cartridge outputs 0.5mV then I would recommend using a 1:10 ratio SUT which will give +20dB of gain. That will present approximately 5mV to your MM stage.
Having seen some of Slawa's handiwork at first hand I can't say I was too impressed. Most of the SW1X kit is essentially cloned in spirit at least from the designs of Kondo/ANUK but I would take their workmanship any day over SW1X.
